Dual Single DIN install - gap filling?
Hi everyone, i just installed the Power Acoustik ptid-900pkg system on my xB; the system works well, for what it's worth, it does well;
my question is with the install; the setup is a single DIN 7" monitor and a single DIN dvd player/tuner etc.
when installed one above another, they are 1/2" gapped on each side, not to mention the top stick out a bit; but im sure i can adjust that. has anyone experienced the same issue, and
what can you do about it?
plastic?
aluminum?
is there a type of install kit available?
ps. ill post pix in the morn; pls check back if you've got .02 cents
thanks all!
Tesh
plastic?
aluminum?
thanks all!
Tesh
You could use ABS plastic, maybe there is a kit, you could use aluminum, you could also mold the dash around the unit with mat and resin, but that is probably more work than you want to do.
i think im leaning more towards aluminum... that is, if i dont start my fiberglassing soon; then maybe resin...
plastic has got to be much cheaper and easier to use than aluminum...
if anyone has pix; please post them!
who's they? i always seem to run into ppl who dont know the store they work in... and usually they cant find the item; however, i bought a 2'x1' sheet of stainless steel for $5? at OSH here in town; we'll see how much i need; though i'll see if i get it done in one cut...
You can do 1 of 2 things :
Buy a AI dash kit for a matrix and modifiy it or you can find a metra dealer and buy the ABS that has 2 single iso holes pre-cut in the center of the set then you just shape it to the way you need it
TheRedBox
31
Dec 2, 2003 04:53 PM
ScottsXBScion
Nov 25, 2003 10:30 PM
