Installing Rear Camber Shims on xB?
Old Jul 14, 2005 | 02:41 AM
artdoesart's Avatar
Default Installing Rear Camber Shims on xB?
Guys,
finally getting my shims from japan this weekend and well was wondering if anyone had some instructions or pointers i should know about.
Any help would be good.
Thanks.
Old Jul 14, 2005 | 03:02 AM
Prototype_xB's Avatar
wow, importing them??
why not get some OTG spacers?
Check out www.precisionmuffler.com
Old Jul 14, 2005 | 03:25 AM
TXboxdriver's Avatar
i had a "how-to" thread on this
it dissapeared???
pretty easy, behind the drum there are 4 bolts
disconnect wheel speed sensor first
then remove bolts
put shim btw drum and axle
use new longer bolts to re-assemble
plug in wheel speed sensor
drive and be happy!!!!
Old Jul 14, 2005 | 03:27 AM
Dewmerz's Avatar
moved
OTG camber shims are not available yet last time I checked. The install should be similar to the OTG shims except 2 plates are being used on each hub to keep the bolts in line. I could be wrong though. MyBox or squirrel would know better.
Old Jul 14, 2005 | 03:41 AM
/\/\ oh really? Not available?? I saw them on precisionmuffler.com's website for $60
what gives?
Old Jul 14, 2005 | 03:56 AM
Dewmerz's Avatar
OTG (the ones currently out) are spacer shims not camber shims.
Old Jul 14, 2005 | 04:00 AM
rolex87's Avatar
i think ur getting the spacers and the camber plates mixed up. the spacers simply bring the wheel out for a flusher look while the camber plates tilt the wheel like this /---\ so you can run really wide tires underneath
Old Jul 14, 2005 | 05:29 AM
artdoesart's Avatar
yeah getting camber shims from Japan i got a bunch of nice friends who will do as i say anyhow arriving at LAX on Saturday. thanks for the help guys...
but yes dewmerz is correct camber shims allow you to go wide, i got 15x8(+10) so i need all the help I can get.
Old Jul 14, 2005 | 05:42 AM
Grimgrak's Avatar
I've lowered my xb 1 and since there is no camber adjustment oem in the rear would i need these camber plates to get my wheel alingment in spec? If so where can i purchase/import them?
Old Jul 14, 2005 | 11:27 AM
hotbox05's Avatar
no you would not grim. the rears alignment stays the sam,e camber wise no matter how low you drop it
Old Jul 14, 2005 | 12:23 PM
i just wish there was a way to move the whole axle back
since when you lower this type of suspension the tire gets closer to the front of the wheel well
Old Jul 14, 2005 | 12:42 PM
hotbox05's Avatar
exactly. it looks horrendous on most bagged boxes. but oh well. it doesnt look too bad with a 3 inch or so drop. once u go lower than that is when it gets nasty.
Old Jul 14, 2005 | 03:48 PM
squirrel's Avatar
it dissapeared???
then remove bolts
Actually, there is a backing plate that's installed also besides the camber plate.
There maybe a company releasing rear toe correcting spacers/shims thru 886motorwerx before the end of the year. Testing/R&D is currently being performed.
Old Jul 15, 2005 | 04:00 PM
Guest
Guest
Posts: n/a
Not available yet, But so close I can smell the fresh engraving. :D Don't worry as soon as I know from OTG , Scionlife will know.
kleecker
Jan 9, 2015 02:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
