Has anyone taken apart the dual halos?
Old Jul 20, 2005 | 06:13 AM
sensez's Avatar
Default Has anyone taken apart the dual halos?
Old Jul 20, 2005 | 06:23 AM
ThunderGod's Avatar
why, what u gonna do?
Old Jul 20, 2005 | 01:26 PM
Simplyscion's Avatar
Team No Limitz
Dual Halos suck...they fog up right outta the box and you wanna take them apart?? Have fun suckin moisture outta your headlights everytime it rains or gets foggy. I would rather do a retro fit to the OEM headlights.
Old Jul 21, 2005 | 02:22 AM
sensez's Avatar
dunno...
just curious...
sen-
Old Jul 21, 2005 | 02:30 AM
peabe's Avatar
throw em in the oven for like 5 mins at 250. but even after i resealed them they fogged. so just drill 3 holes in em.
Old Jul 21, 2005 | 02:36 AM
sexyscionlover's Avatar
yes people have. infact Jay (windowtint) has and paint matched it on the inside. it looks freakin awesome. after seeing pics of it, i think all dual halo owners should. thats just my opinion though. but to answer your question, yes people have.
scott
Old Jul 21, 2005 | 02:43 AM
Slammed04xb's Avatar
funny. . .i dont know if im the only one but mine havent fogged at all
Old Jul 21, 2005 | 02:46 AM
neckbonenick's Avatar
Yes infact I have them apart right now to upgrade the leds in the halo's. Why do you ask?
Old Jul 22, 2005 | 02:31 AM
sensez's Avatar
i was thinking about upgrading the halo's leds myself...
hows the projecto coming?
sen-
Old Jul 22, 2005 | 03:23 AM
well I got my white 20,000 mcd leds from ebay. and I dissembled the lights. I finished one set running 1 pair of led per wire with a 220 ohm .5 watt resistor.
I only need a couple hours more but I've been busy so I haven't finished.
Old Jul 22, 2005 | 03:48 AM
BEASTXB's Avatar
hey nick you have any pics or advice on how to take them apart?
Old Jul 22, 2005 | 04:03 AM
sensez's Avatar
i'd like to see pics and def a write up after the project...
good luck
sen-
Old Jul 22, 2005 | 04:09 AM
ditto ^
sounds awesome nick. good to see some people doing cool DIY projects !
Scott
Old Jul 26, 2005 | 09:54 PM
biohazardous_customz's Avatar
ditto I would love to see the write up
Old Jul 30, 2005 | 07:36 AM
ThunderGod's Avatar
Take off the grill, bumper, headlight, wire harness, w/ appropriate tools. 10mm socket/wrench, ext. , philips & small flathead screwdriver.
I went ahead and took out the Projectors, LED, but not the HALO's (just to see how things are.)
Prepare for the oven
In the Oven, 250 F for 5-7 min. (gauge temp. & min.) Easyoff oven cleaner optional j/k I know...it's dirty.
Pull apart Lens/cover w/ your fingers. (do not use sharp object) Be patience and work it. If need be, Re-heat in the oven to soften the seal.
Clean out/off old seal.
Use clear or black waterproof/resistant silicone sealer. (original seal is Black)
Apply seal and run a good bead. Clean off excess run off w/ finger & wipe clean.
After putting the Lens/Cover back on, check the contact w/ Lens and the housing that it sit's properly. I put the housing under a couch cushion, and I added some weight to it so that the Lens/Cover will set firmly on the housing. (Cure time depend's on the product.)
Re-assemble Projectors and LED's
Put everything back as it should, and there ya go!
Hope this helps in some way.
Old Jul 30, 2005 | 10:28 AM
aireck's Avatar
wish you posted this back when i had mine but not regreting the HIDs i have now....
good write up and should be FAQed!!
sabot7726
Apr 28, 2016 08:20 AM
mischman
Sep 15, 2015 03:38 PM
umnitza
Sep 1, 2015 08:06 PM
umnitza
Aug 21, 2015 12:35 AM
umnitza
Jul 25, 2015 07:54 PM
