Spare tire on the hatch: xB
Old Jul 20, 2005 | 10:55 PM
Box916's Avatar
Default Spare tire on the hatch: xB
Well, I've waited for cbarsi's response to how he mounted his spare tire on the rear hatch, and havn't heard back. Is there a kit I could purchase that would fit on the back, or would I have to go to a pick-n-pull and make one fit?
Old Jul 21, 2005 | 12:53 AM
Dansthunder's Avatar
DeepSouth Scions
I was just thinking about that today. I haven't thought about mounting yet, jus wondering what it would look like.
Old Jul 21, 2005 | 01:19 AM
Prototype_xB's Avatar
*shudders*....the thought of that sounds hideous IMO
Old Jul 21, 2005 | 01:31 AM
DeepSouth Scions
Has anyone been able to mount the spare under the car yet?
Old Jul 21, 2005 | 01:52 AM
grnxb's Avatar
I'm with you...unless someone has a really good pic. And then I'll still think it's a bad idea. If I had to mount the spare outside of the car, I'd just buy a can of Fix-a-flat and/or sign up with AAA.
Old Jul 21, 2005 | 02:05 AM
sexyscionlover's Avatar
i dont know. it might be kinda cool. like old Continental style. i think if someone did it, it would be better than it sounds.
someone needs to get on this!!
scott
Old Jul 21, 2005 | 02:11 AM
Lonely_Raven's Avatar
Wondering that myself.
Old Jul 21, 2005 | 03:11 AM
RedMatrixXRS's Avatar
Old Jul 21, 2005 | 03:30 AM
I would still like to see a pic though. Now i'm rather curious. It'l look like a mistu Montero Sport, haha.
Old Jul 21, 2005 | 03:31 AM
wouldn't even be a box anymore. More like a box with a backpack
Old Jul 21, 2005 | 03:36 AM
SCXB's Avatar
Default Spare tire on hatch
I just sold my 02 wrangler and I bet you could use the carrier from a wrangler. It attaches to any flat surface and takes 4 bolts .You could also use the jeep bump stop to keep it from rattling and hitting the wiper.Just not sure how much weight the hatch can hold, and thinking of it I would hate opening the hatch everytime with a 30lb wheel and tire on it. Good luck send a pic!
Old Jul 21, 2005 | 04:16 AM
stick_1NZ's Avatar
Go for it if you don't mind being the SL guinea pig. Props to yah.
Old Jul 21, 2005 | 04:19 AM
Max2k's Avatar
You'd need to seriously consider how the hatch struts funciton. You'd probably end up needing to do two things: install new, stiffer struts and reinforce the areas where they attach..
Old Jul 21, 2005 | 04:30 AM
/\/\ thats a good point. That hadn't even crossed my mind
Old Jul 21, 2005 | 04:48 AM
ChrisLimEditionXB's Avatar
i don't think it is a good idea bc it might be too heavy for the trunk door....
Old Jul 21, 2005 | 04:59 AM
UBOW's Avatar
It would be too heavy. The hatch would not stay up. You may want to consider a swing-away tire rack that has hinges mounted above and below the left rear tailight.
Old Jul 21, 2005 | 05:37 AM
scionracerxb's Avatar
theres some guy on here with a woody kit on his xb with the roof rack, and surfboards on top, and he has his spare mounted on the back.
Old Jul 21, 2005 | 05:41 AM
crayonBOX's Avatar
*when it comes to being on the hatch; i agree w/everyone on the idea of checking the ability of the struts to hold up the hatch ( I KNOW you'll have to get heavier duty ones...) and also maybe consider the way it is attached to the car... those pins are rated to a certain shear strength...
*when it comes to mounting underneath...
ive tried this; because i didnt want to loose my spare becuase of air ride... soo....
the only way you can is to move all those fuel management (?) boxes from the underside...and from what i hear, it's not a walk in the park to make it work afterwords (that green xB w/the cusom air setup from mini truckin i believe)
w/o moving anything it would protrude downwards a bit too low..and it would be angled...
Old Jul 21, 2005 | 06:26 AM
Malthorn's Avatar
It would be nice to have a full size spare with out losing cargo space.
Old Jul 21, 2005 | 07:03 AM
Max2k's Avatar
What you run into here is the strength of those areas. A full sized spare is a heavy item, and a full size spare on a 2 foot swinging arm is going to put a lot of stress on some sheet metal and plastic.
