a few ?s before install of CAI
i'd like to start off by saying that i did search before asking this question. i'm fairly certain this has been covered before but i couldn't find anything...
so i just got my K&N Typhoon CAI and i'm planning on installing it tonight.
1) is disconnecting the negative battery cable the way that you reset the ECU, or is there something else that has to be done? (and also is this necessary at all?)
2) right after the install... should i start up the car and let it sit and idle for any period of time or do i just take off and drive?
any other suggestions would be appreciated also.
2. Yes, start up the car and let it idle for about 15 minutes so the o2 sensor can get used to the intake.
2) Definitely let the car idle for at least 5-10 minutes. It's gonna be hard to resist, but I would suggest not mashing the throttle for the next few miles.
^^ I misread his question... I thought he said "is disco'ing the batt cable the *only* way"....removing that fuse bypasses the need for disco'ing the battery. The benefit is of course not losing your trip mileage, and more importantly, not losing your radio presets, or having to reset the windows/sunroof
Good point though. If you arent worried about shorting out anything under the hood you are better off leaving the bat cable connected and using the fuse.
alright i just got done installing it and everything went pretty smoothly...
i didn't see all of these posts before i installed it and i only let the car idle for about 2 minutes or so before i drove. i was on it pretty much full throttle. just couldn't resist. could i have f'ed something up? would it be alright if i just go outside now and let it run for a while?
also i can not roll down my passenger side window from the driver's side and my sunroof was acting funny too. this is my main concern. whats up with this?
hold passenger side window switch up and down for 10 seconds then its done. also for the moonroof.
yeah let it idle for 15 minutes.
It wouldnt do any good to let it idle now, unless you un did the fuse/battery before hand.
The window/sunroof behavior is due to the battery being disco'd. So basically you need to "reset" them. do this by turning your car on, but not started. Hold the driver window switch down so that it goes all the way down, then hold it so that the window goes all the way up, and hold it there for a few seconds. Repeat that process on the passenger side, from the passenger side seats (won't work using the driver side passenger switch). Do the same thign with the sunroof
i just installed my K&N Typhoon last weekend... does anyone else think it's pretty ghetto to just have the vacuum switching valve hang there on the bracket, instead of having a hole to plug it into like in the stock airbox? does that thing take any readings from the air, it seems odd to have something that was inside the airbox, now sitting in the engine compartment unplugged.
also not sure if I like the whistling squeaky sound I hear when I am at part throttle -- I only hear it when the window's down, but it bugs me. I'm not looking for any faux turbo sounds. Sounds good when you really get on the throttle though.
question:
I have wanted to get a CAI.. but I have noticed the actual end is down in the wheelwell.. what happens when it rains heavily.. does that thing start sucking all the water in?
what to do? us NY'ers dont get the 300+ sunny days you cali folks do. lol
Originally Posted by [LGS
Static]question:
