I JUST GOT MY LAVA I HAVE A QUESTION?
Old Mar 15, 2004 | 10:02 AM
JESSR's Avatar
Default I JUST GOT MY LAVA I HAVE A QUESTION?
WHEN RUNNING 18INCH RIMS ON THE XB CAN YOU RUN A 40 SERIES TIRE OR WILL THEY RUB...CUZ ON THE LOT I NOTICED THEY WHERE RUNNING SMALLER TIRES.I ASKED THE CAR SALESMAN AND HE SAID HE WASNT SURE...
Old Mar 15, 2004 | 10:23 AM
TSiAWD's Avatar
Default Re: I JUST GOT MY LAVA I HAVE A QUESTION?
Might i refer you here?
https://www.scionlife.com/forums/viewtopic.php?t=348
Btw the tire sizes listed are not always the most accurate sizes so run them thru the following wheel tire calculator first.
https://www.scionlife.com/forums/viewtopic.php?t=7968
BTW that wouldn't happen to be a 5spd would it :twisted:
Old Mar 15, 2004 | 10:24 AM
JESSR's Avatar
YES IT IS A 5 SPEED
Old Mar 15, 2004 | 10:29 AM
JESSR's Avatar
BUT CAN YOU RUN A 40 SERIES WITH A 18X7.5 WITH OUT RUBBING?
Old Mar 15, 2004 | 07:42 PM
CBSIMONSEZ's Avatar
I would think it depends on the offset of the wheel.
Old Mar 15, 2004 | 08:07 PM
Docsnuff's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
Would it be possible for you to not type in all CAPS? It is perceived as yelling...
Thanks,
Doc
Old Mar 15, 2004 | 10:02 PM
kwicslvr's Avatar
Thanks,
Doc
You took the words right out of my mouth!
Old Mar 15, 2004 | 10:08 PM
Docsnuff's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
Thanks,
Doc
You want them back?
Doc
Old Mar 16, 2004 | 06:49 AM
TSiAWD's Avatar
A 40 series is "thicker" than a 35 series but not any "wider"
a 5% difference in w/h ratio is not going to make a huge difference in the sidewall "bulge" so I forsee no problems, other than the fact that they are going to be taller than stock size so you will lose some acceleration and be travelling faster than the speedo says.
I'm "assuming" you will be using a 225/40R18 and not a 235.
If so the tread part of the tire will be 1.57" wider , call it 2" in the middle max.
However it will be +1.35" in height, leading to a speedometer error of 2% slow
Ie if when you are doing 60 miles per hour the speedo will read about 56mph
for an actual speed of 70mph the speedo will read 66.
Something to keep in mind, you will be right at the 4-5 mph over that it takes to get "popped" if you are running the "right" speed on the speedo.
a 225/35r18 is only 1/2 taller, so the speedo stays accurate (most speedos are optimistic by 1-2 mph generally at 70 so for all purposes there is no error)
ie at 70mph the speedo should read 69/70
If you want 18"s then get the right size tire, if you want the thicker sidewall then get 17"s
Just my 2 cents
BTW I really really am jealous. Our delear got allocated 2 automatics instead of a 5spd for us, so every day it looks less and less likely that we will get a rs1 5spd unless I go to another area of the country like SET. GST is not getting nearly enough rs1's considering they have Texas, Louisiana, Misssissippi, Arkansas, and Oklahoma. Texas is a big state and 13 -25 5 spds for the whole region is a joke!
My wife is really really ____ed after waiting 6 weeks since they went on sale here and we still don't even know if the dealer can get one,
Old Mar 16, 2004 | 07:18 PM
its_ikon's Avatar
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
