137.54hp Super Charged xB DYNO sheet posted....
Well all I can say is wow. The only change from my dyno of 120hp at the is a hi-flow cat. I also added a Cam-Con. It has helped with the low end I lost by changing out my whole exhaust. Now I am going to upgrade my injectors. As you can see I am still running lean. I may get a rear O2 eliminator to help throw some more fuel. I should have a little bit of higher numbers when the weather cools down. Hotter than hot here makes for crappy dyno runs. 98 degrees with 29% humidity. I may end up running a SMT7 to over ride the factory mass air flow sensor. This morning I pulled my mass air flow sensor and it made a big difference. I could tell it was throwing more fuel.
um you mean 136.33 - 137.54
that is unless you have a real way to test power loss thru the friction of the transmission. which i highly doubt.
either way. all people i know judge cars by whp.
nonetheless even with 137whp, sweet numbers that i could only dream of having!
btw you should probably edit that subject line to at least say "160bhp dyno posted"
good luck with the next mods!
-jon
I had posted before the percentage because I kept getting PMs about how much power at the crank. Also, if somebody can find me the wheel hp on a stock xB. Even Erics post on the xB engines specs only has engine hp not wheel hp.
Originally Posted by matchbox
I also added a Cam-Con.<snip> Also, will run a piggyback fuel management.
