Figured out Cam-Con problem.
Old Jul 24, 2005 | 12:07 AM
matchbox's Avatar
Default Figured out Cam-Con problem.
I had dynoed Friday and turned a 137hp at the wheel. Only problem is the Cam-Con was only throwing more fuel at the lower RPMs. I pulled my air flow sensor this morning and cleaned it. I also, had to go out of town and drove about 50 miles. I noticed when I got on the highway that when I let off the gas up in the higher RPMs that the engoine was bogging down. Like it was too rich. I dialed the fuel down a little bit. Ands now it pulls hard all the way to redline. I think it just took some miles for the ECU to adjust or it was from the dirty air sensor.
Old Jul 24, 2005 | 12:17 AM
eggie's Avatar
INteresting.. You going to do somemore work an redyno it?
Old Jul 24, 2005 | 01:30 AM
matchbox's Avatar
Default injectors
I have some injectors on the way. I will redyno it after that point.
Old Jul 24, 2005 | 01:37 AM
dgHotLava's Avatar
injectors are a big help.
you should be happy with the swap.
Old Jul 24, 2005 | 03:20 AM
lastlookcustoms's Avatar
Default Re: injectors
What did you go with for injectors?
Old Jul 24, 2005 | 04:58 AM
squirrel's Avatar
Yeah, usually when I do some type of mod that effects the MAF and ECU, I'll drive the xB for about 10 miles on the freeway accelerating gently, park and then turn it off. I wait a few minutes then drive 30 miles on the freeway, and then find a spot to park and turn the car off. After a few minutes, I start back up and everything should be reset and be good to go.
Old Jul 24, 2005 | 03:32 PM
Simplyscion's Avatar
Team No Limitz
Hey Matchbox...any way you can talk to your PE distributor and see if you can get a couple extra in tank regulators from them for me and Stu??
Old Jul 25, 2005 | 03:47 AM
matchbox's Avatar
Default PE
I don't deal with a PE distibutor. I am PE direct.
Old Jul 25, 2005 | 03:51 AM
Team No Limitz
Default Re: PE
so any chance then
Old Jul 25, 2005 | 10:35 AM
Yea, thats what I am saying. I bought the pump from them and now I just need that regulator bypass or the larger regulator...However they do it.
Old Jul 26, 2005 | 02:10 AM
SuperCrunchyAction's Avatar
How safe is this? Most serious tuning involves a wide band o2 sensor to ensure accuracy. How much confidence do you guys have in this product?
Old Jul 26, 2005 | 03:00 AM
Team No Limitz
Got the wideband oxy sensor already
Prolific998
Scion tC 1G ICE & Interior
Apr 16, 2017 06:09 PM
Forced4
Aug 25, 2015 08:18 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
capgrover
Jul 25, 2015 05:00 PM
blackpearlTC
Jul 19, 2015 04:55 PM
