More BLING...
Old Jul 27, 2005 | 05:40 PM
Weapon-R's Avatar
Default More BLING...
Here is the Monster Motorworks Aluminum Battery Cover.
Welded seams and polished.
Designed to do absolutely nothing except look good.
Just like a Import Tuner Cover Model.
Things you should know about this product.
1. Does absolutely nothing except BLING.
2. Battery terminals " DON'T " Touch the Cover.
3. Yes it fits SNUGLY over the " OEM " Battery.
4. Made in USA.
5. Every Piece welded in House.
6. Every Piece Polished in House.
7. Every piece is Made in House.
8. It goes for $65.
Old Jul 27, 2005 | 05:43 PM
malina's Avatar
I'll give you $12 and a Big Mac.
Old Jul 27, 2005 | 05:51 PM
Weapon-R's Avatar
Thats too nice of you.. But you sure you can afford that?
Old Jul 27, 2005 | 05:55 PM
malina's Avatar
I suppose I can go combo AND Super Size if you play your cards right.
As for the battery cover... interesting concept, something I've never seen or thought of before but not something I'd put on my car.
Old Jul 27, 2005 | 07:12 PM
maximus96's Avatar
why no hole for the indicator? you'll need to disconnect power in order to check
Old Jul 27, 2005 | 07:40 PM
BrEaK_AwaY's Avatar
curious to see how fast someone shocks them self with this... or a hot shot...
Old Jul 27, 2005 | 07:44 PM
ack154's Avatar
I think it would look a little better with round terminal holes. Would look cleaner, IMO.
Old Jul 27, 2005 | 08:20 PM
Weapon-R's Avatar
the terminals are raised.
Stock it has about a 4mm space from the base of the battery to the ending point of where the battery terminal would end when you install it.
you should be able to tell that when you look at the pictures.
SO shocking yourself would be crazy if your just careless.
Old Jul 27, 2005 | 08:29 PM
engifineer's Avatar
Sorry to point out the negative (no pun intended), but one reason stock batteries are not metal on top is so that corrosion and moisture/condensation cannot build up and cause a short across the top of your battery. Maybe not a short that you will see right away, but one that will slowly drain your battery. I have even seen this happen on regular batteries that dirt was allowed to build up on. It wouldnt take too much crud to bridge the gap between post and metal cover there. Enough condensation (which the cool metal top would be a perfect hiding place for in the cool damp morning) would easily make your two posts one electrically. Just an observation
Old Jul 27, 2005 | 09:13 PM
Weapon-R's Avatar
I do suggest people getting the cool Green and Red terminal protectors form Kragen or whatever to help stop corrosion.
Corossion is something you just cant get around.
But those terminal protectors are lik $2.99
Old Jul 27, 2005 | 10:14 PM
BrEaK_AwaY's Avatar
they wont help much with that cover on the battery.
engifineer made a very good point.
Old Jul 27, 2005 | 10:22 PM
Weapon-R's Avatar
Fit fine with no problems on our customers TC.
But to each their own.
