Spacer and wheel question
Old Aug 4, 2005 | 01:20 PM
Subcompact Culture's Avatar
Default Spacer and wheel question
I just bought a set of 18x7 +40 wheels for my xB. I will probably end up buying OTG's spacers hub shims (those are 10mm, right?). With a +40 and a seven-inch-wide wheel, is it possible to get the rear wheels flush (or close) with the fender? I've seen some pretty crazy 25mm spacers with studs built in from TC Sportline; are these safe? Do people run the hub spacers and the wheel spacers?
Any input would be great.
Old Aug 4, 2005 | 02:49 PM
squirrel's Avatar
Most peeps are running one or the other.
An 18x7 +40 w/ an OTG rear shim should flush out nicely. A +40 on a 7 inch wide wheel will put the wheel just inside the fender lip.
By running both, you place added stress on all of the bolts concerned.
Old Aug 4, 2005 | 02:59 PM
I see; thanks.
Old Aug 4, 2005 | 03:16 PM
Lonely_Raven's Avatar
Not only the bolts, but isn't that stressing the bearings too?
Old Aug 4, 2005 | 03:22 PM
squirrel's Avatar
Yes, the bearings also.
Old Aug 4, 2005 | 03:45 PM
CoffeeBean's Avatar
Default New Wheels for my XA
Ok,
This seems to be the right place to ask:
The wheel in question:
17x7 - 4x100 - 40 - BR
Tire: 205/45/17
Would it need wheel spacers? Or would this by itself give the overall car a streamlined appearance? Also how about the stress issues you mentioned?
Thanks for any answers and recommendations!!
Old Aug 4, 2005 | 04:43 PM
You wouldn't "need" spacers. They'll fit fine. However, the rear wheels are pushed farther in towards the body without them which, to many people, is not a desired look.
Old Aug 5, 2005 | 06:45 PM
CoffeeBean's Avatar
Thanks for the info...
As for the topic of spacers: based on the previous specs of my XA, would anyone recommend a type of spacer to order when purchasing my wheels? Would you only recommend spacers for the rear wheels in order to best streamline the car's overall appearance?
I am certainly a newbie on this subject...
Thanks!
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
terrye
Jan 25, 2015 05:31 AM
kingofthecrate
Jan 21, 2015 09:28 PM
CAtC12
Dec 23, 2014 04:44 PM
