check engine light
Old Aug 10, 2005 | 06:41 PM
seminoles68's Avatar
Default check engine light
I have the alphawerks header and i did the antifouler and then i disconnected the battery for 30 mins and then let it idle for 10 mins and it is still on is there any other way to eliminate the cel or anything else i can do to eliminate it myself
Old Aug 10, 2005 | 06:51 PM
acasanova's Avatar
Default Re: check engine light
Make sure you use 2 18mm antifoulers, and install both after drilling on the s pipe not header!If you get a CEL , restart the process disconnect battery for 15 min not 30 reconnect and let it idle for 10 no reving, if the CEL pops just drive after the 15 min normally. You have to let the ECU adjust may take 60 -100 miles and the cel should go away. If it does not take it to autozone to get a OBD code, might be a defective o2 sensor. Best of luck man.
Old Aug 12, 2005 | 12:11 PM
I have done everything that I can think of I have even went and got the codes erased and the two codes come back for not having a cat on the car besides the o2 sim is there anything else i can do
Old Aug 12, 2005 | 02:10 PM
acasanova's Avatar
That is weird if you are sure your O2 sensor and relay are fine and working properly, and it is on the s pipe then you will need a SIM. Try the Alphawerk SIM it is the cheapest, if that does not do it get the ZPI unit.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
AdmirN
Jan 5, 2015 10:19 PM
