View Full Version : LSD Install problems for Echo Hatch
ashtaron14
08-10-2005, 10:41 PM
The Echo Hatch in Canada has a C150N tranny
Now we had the tranny overhauled and found that the final drive had 6 bolts and that the LSD has 8 holes. Of course the holes don't line up.
The LSD that I purchased is TRD Part 41301-AW004. Now I was wondering if anyone have any ideas as to what I should do. Should I purchase the TRD final drive set with the 8 holes and pray that the output shaft will align with the gears (I am doubting it will). I am also curious if anyone on here knows if the final gear on the Scion has 6 or 8 holes (if there's 8 I might just drive down to US to find a tranny from a junk yard)
Thanks for your help
Sunny
ashtaron14
08-11-2005, 03:37 AM
Here is a link to some pix of the tranny:
http://www.imagestation.com/album/?id=2122693247
chucksu
08-11-2005, 11:42 AM
:ponder: This is odd. I would think the Canada Echo, would share the same tranny as all the other echos, xA & xB along with most of those other crazy cars that came from that platform. Now the final drive is diff in some of the range, so that might make some difference. I think my first choice would be calling up TRD & seeing what the hell is up. If the LSD says it will fit a echo, then it should fit. If you already did that, what kind of answer did they give you? Sorry I cant be much more help.
Ashe_WCM
08-11-2005, 02:24 PM
Not to sound stupid but do the 6 holes line up correctly with 6 of the 8 holes? if so you could just bolt it on using the 6 bolts and plug the other two holes.
ashtaron14
08-12-2005, 12:41 AM
Nah man those are two totally different bolt pattern. I took a couple snap shots of the factory open diff and the TRD LSD. I'm gonna upload 'em tonite.
Do anyone happen to know what's the tranny code of the xA/xB? Pls let me know, thanks!
Yup we gonna contact the TRD dealer where I bought the LSD from.
dgHotLava
08-18-2005, 10:49 AM
any updates???
