137hp to 141hp xB Cam-Con Dyno sheet
I finally got my dyno sheet scanned in showing the Cam-Con. The first was with the Cam-Con set to 0 on the VVTi settings. The Cam-Con helped to smooth out the hp and tq lines. And got rid of the spike at 5500RPM. I gained anywhere from 3 to 7 hp over the whole run.
Power Enterprise has developed this CAMCON unit to control numerous Toyota/Lexus and Honda/Acura models equipped with variable valve controlled Engines, this unit allows the user to modify and change multiple setting points on the motor including real time timing adjustments with 500 rpm increments and the ability to modify the air /fuel ratio.
$419 but you can find them cheaper. I think there is one for sale in the classifieds.
This does nothing to your ignition timing. It will only modify the air/flow and the VVTi singnals. You can change the settings + or - through a set RPM range. The unit is modifying the factory map which we don't know what it is.
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
carid
Aug 31, 2015 11:17 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
