This is a do it yourself tech article to teach you how to install the Creative Compacts A-Pillar 3 Gauge Pod, and three gauges (optional at this point).
Install Time Without Gauges: 20 Minutes
Install Time With Gaues (just running the wires): 30 Minutes
Tools Needed:
Power Drill
Philips Head Screw Driver
Your Hands
Materials Needed:
Creative Compact A Pillar Pod
(2) Screws (included with the CC pillar pod)
(2) Screw Caps (included with the CC pillar pod)
OEM A-Pillar
Small drill bit (or unibit)
Step One:
Removing the OEM A-Pillar
Remove the stock A-Pillar by pulling the top of the pillar (pull towards the passenger side of the car). The pillar should begin to pop out (it is held on by two white plastic clips, and little slits at the bottom for it to rest properly), and work your way to the bottom pulling on it. Once both clips have popped out, begin to pull the pillar towards you (towards the back of the car), and kind of give it a wiggle till it gets free.
See the image below to see where to start removing the stock pillar
Step Three:
Securing the Creative Compacts A-Pillar Pod to the OEM A-Pillar
Now that you have the Creative Compacts A-Pillar adjusted to fit the stock OEM Pillar, you need to secure it to the stock Pillar. Place one of the supplied screws in your power drill, and drill it into the top hole first (DO NOT OVER TIGHTEN), then drill in the bottom screw (DONT OVER TIGHTEN). Once this is complete, take a Philips head screwdriver, and tighten the screws a little bit to make it snug, but don’t over do it. I also recommend taking out the white clip closest to the bottom of the stock A-Pillar for a proper fitment later on during the install. (you can see what clip I'm talking about in step four's picture)
See the image below to see where the bottom screw gets screwed in
Step Four:
Creating Holes To Run Wires/Tubes
**NOTE** If you are not installing your gauges right now, you can skip to Step Seven, or you can do some of these steps now to make your gauge install smoother later down the road.
You will need to drill a small hole behind where each gauge will sit in the pillar to run the wires/tubes (depending on the gauge). To do this, place a small bit (or unibit) in your power drill, and drill 3 small holes towards the back of where the gauge will sit in the Creative Compacts Pillar.
See the image below to see where I drilled my holes to run my wires/tubes (and where I removed the white clip)
You need to remove the black plastic panel below where your side view power mirrors control switch is (to the bottom left of the steering wheel, right above the hood release). You will now run all of your wires/tubes through the holes you drilled in the A-Pillar, and then run them down into where your removed that panel (if you have an rear-view auto dimming mirror, you will run your wires/tubes the same place that wire is run). Make sure you have enough slack to install the A-Pillar, and enough to reach the components that are required to install the gauges wires/tubes.
See the image below to see what panel to remove, and where the wires will be ran to
http://www.scionlife.com/tech/images/apillar_install_tc/192561211_l.jpg
Step Six:
Installing Gauges
Attach all your wires/tubes to your gauges, and simply push them into the holes where the gauges sit. The gauges should sit very Snug, and don’t really need any other support to hold them, but it is a good idea to use whatever hardware your gauges came with to hold it in place even better.
See the image below for the Gauges in the A-Pillar
To install the A-Pillar, you are going to do just the opposite of how you removed it. You will need to start from the bottom, by aligning the 2 pegs with their slots. Once they are in their slots, you need to get the bottom left hand corner of the pillar to rest under the black felt (by the window). To do this, simply pull the felt up with your finger, and you will need to do this the entire way up to ensure the entire A-Pillar is resting under the black felt. While working your way up, you should be able to get the top clip to pop back into place, and the A-Pillar should be holding fine. Now, look towards the bottom of the windshield, and you will probably have a slight gap between the Creative Compacts A-Pillar, and dash. To fix this, you need to press firmly with your thumb, to get it to fit snug between the stock A-Pillar, and dash. Finally, simply push in one of the screw caps on the bottom screw, and the other cap on the top screw,
See the picture below to see the area I am talking about with pushing it with your thumb
Now that you have your Creative Compacts A-Pillar Install (with or without Gauges), enjoy the looks, and benefits it will have once gauges are installed.
** NOTE ** I still have not put the screw caps on the screws because I need to play around with my gauges. Just wanted to inform everyone that so they know the pillar will look even more like an OEM fit with the caps on the screws.
See pictures below for the final product installed:
I give this product an A+. The reasons for this are the following. The price is right on the money, $59.00 plus shipping is a great price for this pillar. The fitment and color make it look like it was meant to be that way from the factory. Install was a breeze and not time consuming at all. Overall it makes the interior look 10x better. I believe James and the guys/gals hit it outta the ballpark on this one, GREAT JOB GUYS!!!
Marshall
08-17-2005, 01:47 AM
great write-up. the pillar pod looks sweet. this should go into the tech section.
jallamas
08-17-2005, 01:48 AM
:bow: Nice, great install and write-up!
John
GoSwim
08-17-2005, 02:15 AM
Oohh...Aahh; nice write-up with good pics. :clap:
XD40tC
08-17-2005, 02:57 AM
What guages did you use and where did you run/connect them to? Oh and why? lol
i only have the voltmeter installed right now, ill be doing the others later
Marshall
08-17-2005, 03:44 AM
I'm going to have to get me one.
BTW: I have the same DKNY watch... kewl :P
BigKid
08-17-2005, 04:46 AM
Nice...
Great write up. And even better to some good photos to go along with it.
2 thumbs up! :clap:
insanetc
08-18-2005, 01:40 AM
looks awesome...is the finish like the fabric or vinal..??but i deff getting one looks great
BrEaK_AwaY
08-18-2005, 01:47 AM
it is a plastic, but the color matches very well. you wouldnt be able to tell its not covered in the same fabric unless you sit there and look at it for a while. i deff recommend this product.
if anyone eles has questions about this, please feel free to ask me
insanetc
08-18-2005, 01:49 AM
thanks yah i deff looks good.....and you cant beat 59 bucks...lol....what kind of aguges did you use and what brand...i lik eth c/f
BrEaK_AwaY
08-18-2005, 01:52 AM
i used Auto Meter, Carbon Fiber Series. Voltmeter, Oil Pressure, and Vac/Boost (up to 20psi)
DTRUONG_112
09-22-2005, 01:41 AM
i like it.
Acsilva84
09-22-2005, 08:23 AM
thanks. great write up
BrEaK_AwaY
09-23-2005, 12:24 AM
ty, hope it helps
Dark-Nes
09-23-2005, 09:47 PM
Where can I get one? is there a web site because im in NYC
BrEaK_AwaY
09-24-2005, 12:32 AM
www.creativecompacts.com
Nebraska_tC
09-28-2005, 10:23 PM
where do you attach the wires from the guages to?
BrEaK_AwaY
09-29-2005, 02:40 AM
depends on the gauge. kaeon made another DIY got gauge installations, it can be found in the FAQ section.
mwuf15
12-28-2005, 01:56 AM
which is better? machinical or electrical gauges? and which one is easiest to install?
Wes910
02-25-2006, 08:14 PM
what if u have the curtain airbags????
jct
02-26-2006, 02:46 PM
cannot use it sorry
Nick06tC
04-06-2006, 09:11 PM
Awesome write up. Installing tomorrow so I am just keeping this thread around.
xDSPxHX320x
04-08-2006, 07:17 PM
Much props to you for this write-up. Great detail... Just what I was searching for. Thanks!
BrEaK_AwaY
04-09-2006, 03:50 AM
thank you =]
fishingexpert87
04-09-2006, 04:08 AM
hey let me ask you, if you have the srs air bags there, can you still install it? or will it deploy once u take that out?
BrEaK_AwaY
04-09-2006, 04:11 AM
no, you can not use that pod =\
WhiteWolfG
04-10-2006, 06:34 PM
After you install these gauges... will they do the same needle-jump on start that your dash gauges do?
BrEaK_AwaY
04-10-2006, 07:18 PM
it depends on the gauge's you buy, some do (high end gauges), but most of them do not. the pillar pod has no effect of that, neither does the wiring
vaccaro
04-23-2006, 04:29 PM
Tools Needed:
Power Drill
Your Hands
Materials Needed:
OEM A-Pillar
Step One:
Step Three:
Step Four:
Step Six:
Installing Gauges
Do you know where i can find the dimmer wire... i can not figure out which one that is..
miamibusta69
06-18-2006, 12:29 AM
Ok well i have the tinted series gauges from wwww.glowshift.com and they are not fitting in the holes at all.... A guy at my scion club has the same ones installed in his..
Nick06tC
06-18-2006, 12:38 AM
it was an extremely tight fit for my autometers. I was scarred i was going to break something.
BrEaK_AwaY
06-18-2006, 06:55 AM
the fit nice and snug for me like they are suppost to
miamibusta69
06-18-2006, 09:54 PM
so just slam them in straight on or at an angle and pop the other side it ..
BrEaK_AwaY
06-18-2006, 11:03 PM
put them in straight, and twist them while putting them in. it should be a tight fit.
miamibusta69
06-19-2006, 12:20 AM
got them in.... had to scrape away a lil bit with a knife and use a lil soap.
any one know how to install a oil pressure gauges?
BrEaK_AwaY
06-19-2006, 12:29 AM
depends on if it is electric or mechanical. if mechanical, sell it because u do NOT want to run an oil line into the car
zer0
06-19-2006, 12:40 AM
Yea for Elec, just put this on the oil filter housing, then attach your filter.
http://cgi.ebay.com/ebaymotors/OIL-FILTER-SANDWICH-PLATE (http://cgi.ebay.com/ebaymotors/OIL-FILTER-SANDWICH-PLATE-SCION-tC-xA-xB-NEW-IN-STOCK_W0QQcmdZViewItemQQcategoryZ33613QQihZ019QQitemZ8075627688QQrdZ1)
miamibusta69
06-19-2006, 02:27 AM
um its electric it only has wires... and the gold this shown here
will that thing the guy above showed me work looks alot easier .. or is it?
zer0
06-19-2006, 02:32 AM
That is exactly what I use for my Oil Pressure gauge. It works and its super easy to install. :D
miamibusta69
06-19-2006, 02:34 AM
any any cheaper places 50 bucks ouch.. more than my gauge LOl
miamibusta69
06-19-2006, 02:41 AM
w/e ill dot hat crap later my gauges are in so no one knows they arent connected yet.. they are tinted lol. plus i wont have my car for a week (bodykit) :)
jwaggz82
06-19-2006, 02:42 AM
$5o is pretty much the starting point of anything good. The least you are going to find anything less for is about $30ish.
BrEaK_AwaY
06-19-2006, 02:44 AM
i wouldnt get the one he listed on ebay. i would get greddy's oil block adaptor. which is what i use. i wouldnt of got the gauges u got either cause they look cheap and probably arnt accurate IMO.
miamibusta69
06-19-2006, 02:49 AM
they are just for show.... nothing else :) i just want any oil leeks.
zer0
06-19-2006, 02:52 AM
That is the exact same one I use, and I have 0 problems. They are all made with the same material, just Greddy is way overpriced. :lalala:
BrEaK_AwaY
06-19-2006, 02:54 AM
i paid 45 brand new for greddy =]
miamibusta69
06-19-2006, 02:57 AM
websites....
zer0
Thats a good price, but the cheapest Ive found was $62, and $55 from a Sponser on here. So I bought the MaxSpeed one.
BrEaK_AwaY
06-19-2006, 03:01 AM
miami, i got hook ups, so i cant post a website. but thats awesome zero, as long as it works with no leaks, no complains =]
zer0
06-19-2006, 03:05 AM
dont understand where it would leak from... :P I have no complaints.
BrEaK_AwaY
06-19-2006, 03:10 AM
the o ring where the block adaptor screws into where the oil filter would screw into. or where the filter screws into the block. one of them or both can leak
zer0
06-19-2006, 03:12 AM
Teflon on the Screws, and the O-ring is money! MaxSpeed FTW. :lol:
Now hook me up with Greddy parts for dirt cheap..all the sponsers on here would not come close to $45.
BrEaK_AwaY
06-19-2006, 03:14 AM
i got some personal hook ups, i cant give out their info cause then word might spread and my guys would get ____ed at me. but trust me, it only cost greddy like .30 to produce them.... if that
miamibusta69
06-19-2006, 03:15 AM
ok break away ill be talkking to you very soon . ill be ordering two.. that is if you let me in on your secret site lol..
thanks for all your responses .. o and could some one post a pic of the top of the pillar hwo its supposed to look? ill post mine soon its a lil off :(
zer0
06-19-2006, 03:18 AM
Mine fits like a glove. I bought mine through GaugePods.com which makes them for CC I believe. Ill post pics when I finish my wideband wiring.
BrEaK_AwaY
there is no website, it is a personal contact in which i will not give the info out.
jwaggz82
06-19-2006, 03:22 AM
why would you even go through all the posts if you arent going to give people the hook up ... or for whatever reason ...you cant give them the hookup?
zer0
06-19-2006, 03:29 AM
Because he could get his friend in major trouble for selling under what Greddy allows.
BrEaK_AwaY
06-19-2006, 03:31 AM
because zero made a comment about greddy being over priced (which tey are in alot of thair parts) so i had mentioned i got it for much cheaper with a contact of mine. i have many contacts in the automotive world, and some of them would like me to keep their information on pricing private. and since i released the info on their pricing, i wont release the name
jwaggz82
06-19-2006, 03:36 AM
word
miamibusta69
06-19-2006, 03:37 AM
then il buy the one from ebay :ttth:
zer0
You will not be disappointed. :D
Spoolin
09-05-2006, 12:50 AM
awesome write up
Eppopipe
09-20-2006, 08:55 AM
has anybody installed a air/fuel and oil pressure gauge in the tc
and how does everybody elses cc pod look
mine was hell to get lined up after i ran the wires.
WeDriveScions
09-20-2006, 09:00 AM
Lots of people running a UEGO or similiar guage, plus all the other setups and such...
I decided against running it, as the pods didn't line up well enough for me and don't want cops to see lit guages in my car... Good setup for cheap though.
vaccaro
09-20-2006, 11:37 AM
what will the cops due if they see lit gauges.. they see mine all the time. You can not get pulled over for having lit gauges.
vaccaro
09-20-2006, 11:40 AM
mine was hell to get lined up after i ran the wires. I have A/F which i ran into a problem with. You have to drill in to your header. if you get the narrow band. Next time i will purchase the right type of gauge so i can tap right off my ecu. I have voltage and water temp. as well.
BrEaK_AwaY
09-20-2006, 12:12 PM
if u get a a/f ratio, get a wide band by aem like WDS was saying. one of my gauges installed are oil pressure, and to install this properly, you need an oil block adaptor (i got mine from greddy i believe)
vaccaro
09-20-2006, 12:19 PM
yeah i tried to hook my a/f through my ecu. But i was told i would have to tap from the exhaust manifold or the headers. Whats the worst that could happen if i am leaking in either of those area's?
vaccaro
09-20-2006, 12:27 PM
if there are minimal problems that could accure. i will drill and tap it myself.
BrEaK_AwaY
09-20-2006, 01:06 PM
ur header and exhaust manifold is the same thing. a header is an exhaust manifold.
some wideband a/f ratio sensors have their own sensors (i think aem's is like this) to where u would have to tap into the spipe (not the header) with a new bung. I would suggest u let a performance show / muffler shop / or someone who can weld a bung into the pipe.
vaccaro
09-20-2006, 01:08 PM
i am a welder myself.. but i guess i could always let some one else do it. what are the side effects of a leaking header?
vaccaro
09-20-2006, 01:25 PM
what i am asking is if i drill a hole. and i some how do not do a good job welding.. what are my side effects going to be. Will the car still run ok? will it even start?
BrEaK_AwaY
09-20-2006, 01:46 PM
it depends on where u drill and where u are leaking. if you have a leak before your wide band o2 sensor, your going to have problems, and you will probably run lean because the sensor isnt detecting as much exhaust flow, so in return, you wouldnt feed as much fuel (because the ecu assumes that car isnt taking in much air either), there for running lean.
vaccaro
09-20-2006, 01:47 PM
if i drill after?
BrEaK_AwaY
09-20-2006, 02:56 PM
u should be fine, because i think u have to drill inthe spipe anyway
WeDriveScions
09-20-2006, 08:33 PM
LoL... they won't do much if they see guages in my car, but when they start looking elsewhere, as a result of noticing the lit guages... Umm... could not be the best situation... :(
I may run them and wire them to a switch, so I can turn them on/off... to see them when I need to, and for shows... but keep it quiet inside most of the time... (I like quiet and sleeper)
Eppopipe
09-21-2006, 07:13 AM
ok so i have a issue....
how do i hook up these gauges
a diy would be very very apprciated
i have all autometer procomp gauges.
a/f ratio
volt
oil pressure
how do i wire these in????
where
what to tap
do i need to buy more stuff
do i need to goto a shop and spend some money? (hope not)
help!
WeDriveScions
09-21-2006, 07:57 AM
I comprimised and am going to get my CC A-Pillar pod color matched, as the color is WAY off, and pop in in. I have the autometer CF Pyro/CF Boost and AEM UEGO Wideband for it... just going to run the lights of the guages to a switch so I can shut them off for staying sleeper and hassle free night driving.
Your Autometer A/F procomp guage is worthless (at it is narrowband and tells you NOTHING effective), return it and get something else in it's place, if you go Turbo or such, invest in an AEM UEGO or other "Wideband A/F" controller in it's place... as they tell you acurately what your A/F is at any point in time... but, are pricey
Volt is really easy and just follow the instructions and tap it into 12v supply wire of the deck or cig lighter, or if you really want to, on the ECU...
the oil pressure is a little tougher and clicking features/tech will have a how to from Kaeon on oil pressure tapping suggestions...
-WDS
BrEaK_AwaY
09-21-2006, 01:01 PM
if you wanna save money, and are going FI. i suggest oil pressure, vac/boost, (and because of my sound system) volts.
oil pressure (VERY EASY - and make sure its an electrical gauge, you do NOT want a mechanical gauge because you would be running oil inside of your car): get an oil block adaptor (this is a piece that connects to the oil pan where ur oil filter is connected, and the oil filter will screw into this plate. You will screw the sender unit into one of the pre-tapped holes on the block. You will run one wire from the sending unit to the gauge.
vac/boost (noobie easy): tap into almost any vac line. i tapped into one of the lines to the left and behind of the stock air box
volts (noobie easy): splice into any 12v wire
all gauges: wire them all together for the lights, and find the wire thats hot on when you turn interior dash lights on (stock gauge cluster). you will need a special tool to find this wire. i cant remember what the tool is called even though i have it. but it looks like a screwdriver with a clear handle, and a metal tip. you plus the tool into a wall outlet, and when u put the metal tip to the wire/electric source, if its hot, the handle will light. i know the wire is under the drivers dash around the fuse block, but i cant remember what wire. once u find the wire, splice the wire, and your done.
if you dont think u can follow what i just said, go to a shop cause i dont want you to mess up your car, or find a buddy who knows what he is doing.
Eppopipe
09-21-2006, 04:40 PM
well i cant return it i bought it used...
so the a/f is worthless then
i heard it would work on a N/A application.
theres three wires black(ground)/red(power)/purple(source??)
is there no use for this gauge then.....
and if i may ask
what the hell are these for anyway??
why would somebody manufacture a product that doesnt do anything acurattly??
on that note...somebody tell me if i should just wire it somewhere
or if i should dump out my money and buy some other cheap gauge?
oh and what wire exactaly(what color) if anybody knows is the one i tap into for the lights.
thanks.
BrEaK_AwaY
09-21-2006, 06:02 PM
the gauge isnt worthless to all cars. but it is worthless to ours.
as for the color wire u need to splice for the lights, see my above post, cause i cant remember
vaccaro
10-02-2006, 09:08 AM
i agree.. i did the same thing.. it sux.. hey break away.. how did you get into your sponserships.. just wondering.. a couple of my scioNRG friends told me they just contacted them told them there mods and future mod plans.. and they got hooked up. How did you get ur sponserships?
BrEaK_AwaY
10-02-2006, 10:02 PM
i have a detailed sponsorship proposal that i send to companies i am intrested in
vaccaro
10-03-2006, 06:15 AM
any suggestions of how i should approch these companies?
WeDriveScions
10-03-2006, 06:21 AM
Please take it to PM.... and please search for and read the multiple threads discussing sponsorships...
back to topic please.
vaccaro
10-04-2006, 12:54 PM
ok back to topic here is a picture of my installed pillar. http://www.scionlife.com/gallery/personal/25341_4.jpg
WeDriveScions
10-04-2006, 08:15 PM
Nice.... I'm waiting for my third AEM gauge before throwing mine up... :P Looks pretty though with my UEGO, TRU-BOOST, and soon AEM Oil Temp in it.
MeatRocket
10-23-2006, 01:39 AM
where can i get this pillar pod? itried the creative compact web site but pro tunning comes up and its not on there? any help thanks/
BrEaK_AwaY
10-23-2006, 01:47 AM
unless they stopped selling, it should be there. CC turned into pro tuning
zer0
10-23-2006, 01:49 AM
www.gaugepods.com sells the exact same one, cheaper then Pro Motion.
HOLLYWD69
10-23-2006, 02:02 AM
I have the gaugepods one and I'm happy with it. The only complant I have is the gauges tilt down a little.
eston
10-23-2006, 05:38 AM
To WeDriveScions: what else do you have in your car that is illegal? The police can search all over my car (which I wouldn't allow them to do, considering they'd need a warrant to do so,) and they wouldn't find anything penalising. Nitrous oxide is legal in MI as well.
MeatRocket
04-27-2007, 02:52 AM
sweet i just got the same pillar pod, now i need to put it in
Thanks to awesome guys like you and well done write ups like this, average Joes like me can install the pillar with ease! In fact you just sold me on it. Looking to buy right.... .... now...
BrEaK_AwaY
06-18-2007, 01:30 PM
very kool. glad i could help ya out
ippskidder
02-14-2008, 05:07 PM
sweet.This DIY is exactly what I need. thanks.
BrEaK_AwaY
02-15-2008, 02:54 AM
not a problem. glad to help
Checho
03-30-2008, 09:58 PM
Is this pillar supposed to warp in the heat?
I've had mine on for roughly two months and it seems like there is slight fitment issues in the center, almost like if it was warped.
Im gonna go unscrew it again and screw it back in.
Is it supposed to go OVER the OEM A-Pillar or is it supposed to be attached without the A-Pillar? THe guys that set it up for me screwed it onto the OEM pillar.
BrEaK_AwaY
03-31-2008, 04:38 AM
ive had mine for 2 years (i think.. check the first post, haha) and had no issues. and yes, it screws into the OEM pillar, again. refer to the first post.
jsingh
07-15-2008, 07:04 AM
where does the gauges wires go??
vulgar_wraith
07-16-2008, 01:24 AM
I orderd one of there like 2 months ago still dont have it.No one is answering there phone at promotion tuning.Did they go out of business?
trungchau
09-24-2008, 04:06 PM
hope i can use this for my cf install, just without screwing anything in
double sided tape ftw!!
trungchau
09-29-2008, 05:12 PM
can the cf a-pillar be done the same way minus the screws?
BrEaK_AwaY
10-17-2008, 03:31 PM
i dont know. do you have a pic of it? Is there a skeleton under the CF to attach it to the frame somehow?
ippskidder
10-17-2008, 03:55 PM
Hmmm maybe you could try 3M double sided tape????
trungchau
10-17-2008, 04:03 PM
i was thinkin about doing the 3m
ippskidder
10-17-2008, 04:08 PM
It should work. That way you don't have to mess up the sexy cf.
Just make sure you use enough 3m tape, and be careful when you're installing the a-pillar back in.
Its usually a tight fit. I accidentally cracked my creative compacts pillar, because I manhandled it, lmao.
MeatRocket
10-17-2008, 10:05 PM
lol you said :rofl: manhandled
tcturbo07
12-04-2008, 11:17 PM
Does anyone know if pro motion tuning still sells these pillar pod any more because everytime I call to order I just get a voice recording?
fullFXtc
01-28-2009, 07:11 PM
yea i get the same!!! can we buy these some other place???
tcturbo07
01-28-2009, 08:54 PM
yea i got one similar to creative compact pillar. The website is http://www.gaugepods.com/
TOMMYPHAM
11-11-2009, 04:06 AM
great job man
nrgwar
11-30-2009, 05:31 AM
A++ write up !!!
fullFXtc
12-02-2009, 11:15 AM
wow!! way to bring back an old thread!! lol
turbonetics_tc
12-05-2009, 08:49 AM
Why cant you use a pillar on the scion tc with side curtain airbags.
xchrisx570
11-03-2010, 01:47 AM
i know this is a dead thread, but the only reason i can think of would be if you get in an accident, youre going to be in a lot of pain if 3 gauges and a pillar hit you rather than an airbag.
Eppopipe
12-17-2010, 01:14 AM
I know this thread is way old, but does anybody happen to know if the pod fits 60mm gauges or 52mm gauges?
sergies2001
01-28-2011, 05:42 AM
lookk really good
bikerdude1550
02-03-2011, 09:19 PM
52mm I Think
Hix
02-05-2011, 04:24 PM
Damn elf your sprint to 50 posts so you can sell your stock parts is getting lame.
ReticulatingPigeonElf
02-05-2011, 04:29 PM
im not selling anything. not trying to make post count for classifieds.
thought i needed 15 posts to start threads since it wouldn't let me post in the diy tech area, but i realize now that's not a posting area and have found the right place.
