Fog lights
Old Aug 17, 2005 | 12:15 PM
jjp735i's Avatar
Default Fog lights
From what I have read the connection harnesses for the factory fogs are already there. Out under the bumper and behind the dash. Does anyone know the wire colors and what they are, hot wire, ground, lead, etc... I'm adding some projector beam fogs and would like to hook into the factory leads. Should work fine seeing that the fogs I bought are 12volt system and 55 watts same as factory. Can I asumme on the factory fogs that if you leave the switch on they come on when you turn the lights on like all other cars I know of.
Thanks, jjp
Old Aug 17, 2005 | 12:28 PM
dgHotLava's Avatar
moved...
Old Aug 17, 2005 | 12:36 PM
Limey's Avatar
Doing the same thing next week with hella projectors in the scoops, so i wait with baited breath.
I looked at is300 fogs, but dang ebay and near $200 pricing for fogs.
Old Aug 17, 2005 | 01:07 PM
jjp735i's Avatar
Default factory fogs
Does anyone have the instructions for installing the factory fogs. I'm sure I can figure this out with them. Also does anyone know where to get the factory fog switch.
jjp
Old Aug 17, 2005 | 01:57 PM
LED-Maniac's Avatar
well i would try the dealer for the switch if you want the stock look....otherwise you can go to loews, they have switches that fit perfectly into the cluster under the dash.
Old Aug 17, 2005 | 02:49 PM
socalscion's Avatar
exactly the question i needed answering. does anyone notice a difference between the jdm bb fogs and the usdm fogs as far as brightness?
Old Aug 17, 2005 | 03:22 PM
Bgnome's Avatar
Default Re: factory fogs
jjp
http://www.toyotaparts4u.com/0859052840xBFogLamps.pdf
thats the oem installation guide.
you will need a relay along with the switch, if you intend to use the factory wiring. the relay is not a typical generic part you would likely find at autozone or something so you will either need to get it from the dealer as well, or jerry rig a standard relay. if you do the standard installation, the fogs will only light up when the headlights are on.
Old Aug 18, 2005 | 12:57 PM
Limey's Avatar
Originally Posted by Bgnome
...if you do the standard installation, the fogs will only light up when the headlights are on.
Would I be correct in the assumption that they will only light up if the headlights are on, but not in high beam mode.
If so I'll need to think this one out.
My plan was to have them on all the time, with parking, main beam and high (if the switch is on)
As the ones I'm getting are "driving lights"....cough cough no seriously officer that's what it said on the box.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
