Slack in throttle cable - very easy adjustment
Old Aug 21, 2005 | 01:53 AM
xActly's Avatar
Default Slack in throttle cable - very easy adjustment
I noticed today, while rooting around under the hood, that there was a decent amount of slack in the throttle cable, and it was adjustable...much like the hand brakes on a bicycle are adjustable.
I loosened the locknut where the cable is mounted to its bracket on the throttle body & moved the other nut (was secured with loctite) toward the throttle body about 5mm .
This took almost all of the slack out of the cable.
At rest, the throttle body still bottoms out on its idle adjustment screw. This is important, because if it's adjusted too tight the cable will keep the throttle body slightly open, even when your foot's off the gas...we don't want that.
The gas pedal now feels more solid, and since it engages the throttle body sooner, it's likely that it opens more fully when the pedal is put to the floor.
Has anyone else done this?
Old Aug 21, 2005 | 03:33 AM
xAlex's Avatar
sounds interesting... take some pics for a DIY.
Old Aug 23, 2005 | 06:13 AM
B2FiNiTY's Avatar
It will feel faster than before due to less slack in the cable. A decent DIY mod for those that want to drive around more agressively.
Old Sep 8, 2005 | 07:21 PM
fusionscion's Avatar
i drive a bit more agressive at times..... could ya post a couple pix for a fellow diy liek I? thx............ill try n figure it out, sounds easy enough im just scared about the throttle body being open at no throttle, it owuld suck to start my car and it redlines out or something liek that..............thanks though great diy mod..............
Old Sep 9, 2005 | 01:06 AM
cadaver's Avatar
i did this one myself after seeing it on a corolla website. it really works and the throttle is definitely more responsive. nice and simple diy for those interested.
Old Sep 9, 2005 | 03:35 AM
rebelMan's Avatar
KAD
gonna be one of my first mods :D
Old Sep 9, 2005 | 09:01 AM
hotbox05's Avatar
gonna check my cable for slack tomorrow.
Old Sep 10, 2005 | 09:49 PM
eburgsspeedyxb's Avatar
yeah, as soon as a pic or two shows up, I'm willing to give it a go.
Old Sep 11, 2005 | 03:27 AM
uber-xA-RS2's Avatar
Would I be correct in assuming that this would make the throttle more sensitive, or would it just make it more responsive? The floppy gas pedal was something that took me some time to get used to when I first picked up my xA since my Focus had a pretty solid gas pedal I would love to have that feeling back.
Old Sep 13, 2005 | 03:51 AM
BlueBubble666's Avatar
This should tighten that up. I read somewhere that they do this on purpose from the factory for the granny factor. So they don't jump it into the car in front of them.
Old Sep 13, 2005 | 04:34 AM
87na's Avatar
sounds like a good mod. thanks for the idea
Old Sep 14, 2005 | 08:15 AM
gnar-de-gwar's Avatar
xActly...you rule I just got back from running my car after adjusting my throttle cable and now the pedal feels so much more solid,more sensitive, and WOT (wide open throttle) is achieved faster too!! Maybe a bit too sensitive though I go into WOT a bit too soon, haha...just a few small turns away from the throttle body and I should be good to go
Old Sep 15, 2005 | 03:16 AM
beigemonito's Avatar
Default Need pics for a DIY
Someone please post some pics for a DIY! This is an awesome mod but I need some pics just to make sure im not wrecking something. PLease please please!
-Daniel
Old Sep 15, 2005 | 10:28 PM
I can confirm that this does take care of ALL of the slop in the gas pedal. Nice and tight now and the car feels more "alive" at WOT. This does make the throttle slightly more sensitive but for the good side. This very mod even worked for my friends WRX.
Old Sep 15, 2005 | 10:42 PM
Default any one have pics of this mod?
Maybe some detailed instructions? measurements how to's pics of what to touch etc. Helpity help help guys. My xa needs it pretty bad.
-Daniel
Old Sep 15, 2005 | 10:43 PM
don't forget us boxes could use this lovin too
Old Sep 16, 2005 | 09:17 PM
Xbilly's Avatar
Woah, my cable was really loose, after reading this I figured I'd check it out, but I wasn't really gonna do it right away. Once I popped the hood I was really surprised. I tightened it up immediatly, and then fixed up my girlfriends xa.
Thanks xActly!
Old Sep 26, 2005 | 06:31 AM
Eski628's Avatar
Default YES!!!!
xActly...you rule indeed, thanx for sharing this discovery w/ the rest of us. :D This adjustment gave my shoe/eggshell exactly what I was looking for. Thanx again.
Old Sep 28, 2005 | 01:11 PM
i_think_therefore_scion's Avatar
Thanks for pointing this out. It's something I did on my first car 15 years ago but did not occur to me (yet) to look at on this car. I've been working my way through drivability improvements on my xA and taking the slack out of the cable really "tightened-up" the accelerator response.
I can now say I'm very pleased with the drivability. Not that it wasn't fun to drive "out-of-the-box", but the upgraded suspension, CAI and throttle cable adjustment make my urban commute a "guilty pleasure".
Old Sep 28, 2005 | 05:34 PM
Wheellug's Avatar
I'm short cuz I sit in a wheelchair..
other then that..
PICS PLEASE!
Then I have an idea what I'm reaching for and where.
