Turboxs fuel computer and wideband. NEW PICS
My new toys just came in. They are from Turboxs who just sponsored me on these four things. I got their new DTEC-FC (fuel computer) controlled by a Gameboy , which comes with their knock/shift light. I also got their map sensor , so the FC can use boost to gauge how much fuel to put out. Lhe last thing being the Tuner wideband O2 which will also data log. I just picked me up a red Gameboy Advance SP to use with it. The GB does the data logging. As well as display a number of gauges.
DTEC-FC retails for $375
MAP sensor for the DTEC retails for $119
Knock / programable shift light. Retails for $129
Tuner Wideband O2 retails for $399 This new version is about one quarter the size of the older radio size unit.
Team No Limitz
I saw this stuff back when I picked up my boost controller from TurboXS...I was gonna go this route till I saw the Camcon...now Im having second thoughts about the Camcon
Are you just testing out this stuff for them, I thought it wasnt gonna be available till like Sept-October??
very very nice matchbox! that DTEC is not only going to be über-effective, but freakin' cool and a great conversational element :D best wishes on the install- cant wait to see how everything goes!
-jon
-jon
I got 4 hp from the Cam-Con. Now if that was the VVT-i or the fuel I',m not sure. But when I was adjusting the Cam-Con and had it at -10 all the way from 1000 RPM to 4500 RPM. I had no room to play with. The VVT-i part is OK but the fuel side is lacking. I think in a NA situation it would be OK, but FI I was already to that point.
I have a little secret project in the works. For all you SC FI guys. It should be done by NOPI.
Well it's all in the xB now. This thing is great. I can adjust what RPM and what amount of PSI to adjust the fuel. I'll be hitting the dyno again to adjust it. I'll get some pics up of it installed. Only took about an hour to mount it all.
$1,020 for an engine management system is'nt that bad... but its still alot of money
TurboXS should sponsor me.
But seriously Did you get to the Dyno with the new setup?
I'm curious to see before and after power curve
Team No Limitz
I think I might hafta go this route for engine management...I like the idea of using the MAP sensor for fuel tuning...I think its time to sell the CAMCON
evolving_machine
Oct 21, 2023 01:16 PM
my06tc
Jun 25, 2015 12:18 AM
Atticus_the_XB
Apr 13, 2015 06:46 PM
