seminoles68
08-23-2005, 03:01 PM
does any one know what this means
P0038 ho2s bank 1 sen 2 circuit heater
View Full Version : check engine code seminoles68 08-23-2005, 03:01 PM does any one know what this means P0038 ho2s bank 1 sen 2 circuit heater aarontrini85 08-23-2005, 03:13 PM call these ppl they might know http://www.actron.com/publish/2005/01/19/pdf_english_16298.pdf also you left out the word high at the end of that WeDriveScions 08-23-2005, 04:46 PM Any chance you have an aftermarket header on that baby? If so.... TADA. Go antifouler or O2 Sim. reagulator 08-23-2005, 05:44 PM I have a header and my code is p0420 Catalyst System Efficiency below Threshold BiG_ReD 08-23-2005, 06:14 PM nope dont know zoltiz 08-23-2005, 11:01 PM Seminoles, you need to hang out with real *real* car guys ;) Here are the trouble areas for your DTC (P0038): - Short in HO2 sensor heater circuit - HO2 sensor heater - EFI relay - ECM My guess would be is that sensor heater or heater wiring was damaged when you took the sensor out, it's the one on s-pipe, btw. The fix - new sensor, luckily that second one is cheaper than the one on the header. P0420 possible trouble areas: - Gas leakage from exhaust system - A/F sensor (sensor 1) - Heated Oxygen (HO2) sensor (sensor 2) - Front exhaust pipe (Three–Way Catalytic Converter [TWC]) My guess is that you have an aftermarket header that eliminated first cat, so your fix would be to get this famous cheap anti-fouler mod. If that does not help - then a real 02 simulator, if not - put stock cat back ;) |
