View Full Version : New PICS of DTEC-FC and Tuner Gen 2 w knock light installed
matchbox
08-26-2005, 02:43 PM
The red Gameboy Advanced SP is the control for the Turboxs DTEC-FC that is mounted inside the dash. I added a MAP sender to it. To use the boost as one of the controls for the fuel along with RPM and load on the engine. The unit will display any of the channels as a guage or a digital dash. It can also log the data for later viewing. You can save four different maps within the unit and then be downloaded to a PC. The one AUX in can be labeled any way you want it to be.
For around $893 retail this is a great setup for anybody running larger injectors in a FI setup.
http://home.earthlink.net/~xbinnc/sitebuildercontent/sitebuilderpictures/08-25-05_1636.jpg
This is Turboxs's new Tuner Gen II wideband . The unit is much smaller than the previous models. It also has a five volt out to drive a piggyback sytem or a narrow band gauge. There is a new connector to allow the logging or one digital and one analog device.
http://home.earthlink.net/~xbinnc/sitebuildercontent/sitebuilderpictures/08-25-05_1635.jpg
This is the combination knock-shift light that comes with the DTEC-FC. It is programmable for its shift points and the knock sensetivety.
http://home.earthlink.net/~xbinnc/sitebuildercontent/sitebuilderpictures/08-25-05_1637.jpg
Simplyscion
08-26-2005, 03:11 PM
So whatsup...does TurboXS wanna sponsor a turbo'd box also to compare the different setups :pray: :P
TXboxdriver
08-26-2005, 03:33 PM
nice!!!
this is probably the answer only some of the turbo xB's can afford but need to!
