hand brake light on during acceleration
Old Aug 28, 2005 | 08:42 PM
hunterUnknown's Avatar
Default hand brake light on during acceleration
I already did a search on this and I got nothing, so if I missed it, someone let me know....
Lately I started to notice that when moving from a stop (red light, sign, etc) and hitting the accelerator, the red hand brake light comes on ("BRAKE"). Only for a few seconds, and maybe 75% of the time. Only during that acceleration. I talked to a friend of mine who works at parts at Toyota/Scion and said that it's probably got something to do with power. Usually, apparently if that light comes on with the battery indicator, then it means the alternator is gone.
Anyway, I'm gonna take it in anyway, but anyone have any ideas to possibly save the trip?
Old Aug 28, 2005 | 09:20 PM
FModFTD's Avatar
Check the brake fluid level. The light comes on when the fluid level goes down too far. When you accellerate, the fluid sloshes back and the sensor sucks air.
Old Aug 28, 2005 | 09:25 PM
good point, ill ahead and check that, thanks
Old Aug 28, 2005 | 10:13 PM
06tCguy's Avatar
yeah, def sounds like the master cylinder. if it's low, don't just fill it, get your brakes checked. it comes on for a reason, and if it's low enough to come on at all, it's likely that your brakes need new pads. how many miles are on the car? how agressive are you with braking?
Old Aug 28, 2005 | 10:30 PM
mikek6789's Avatar
zomg mebe u are sccelorationging so fast dat ur hand brake is going upward a lil bit and it hitting the sensor to turn on da lite, i say u tape dat sucka down
Old Aug 28, 2005 | 11:02 PM
BrEaK_AwaY's Avatar
i just got dumber for reading that
Old Aug 28, 2005 | 11:13 PM
Tomas's Avatar
Admin Emeritus
Yup, I agree, BrEaK_AwaY, but at least it wasnt written in random caps...
Think how much worse that would be, eh?
"z0mG meBe U aRe sCceLorAtioNgiNg s0 fAsT DaT Ur..." That's it, I can't go on...
Old Aug 28, 2005 | 11:43 PM
emiller's Avatar
I had the same thing happen except mine stayed on. Check the brake fluid level. Mine actually looked normal until I took a closer look so wipe away any dirt and look close. Make sure the car is level too.
Old Aug 29, 2005 | 12:29 AM
Emo's Avatar
Emo
Old Aug 29, 2005 | 02:15 AM
ooh you guys were totally right, the fluid is at 1/2 haha
thank you :D
Old Aug 29, 2005 | 02:24 AM
whoa
but yeah i thought of that too
Old Aug 29, 2005 | 01:50 PM
BrEaK_AwaY's Avatar
whoa
in reguards to my last post about geting even dumber after reading mikek6789's post
after reading your responce to his responce...
i have no brain activity.... some one please help me....
Old Aug 29, 2005 | 02:11 PM
haha i just meant i thought of a loose cable as a possibility, but somehow i doubt the tc can be "sccelorationging" that fast, or that a couple steel cables can really be that loose
it's definitely the brake fluid level though.
Old Aug 29, 2005 | 02:26 PM
Dat_Dude's Avatar
that is the stupidest thing I've seen. thats a record on my stupidometer. Do us all a favor, if you don't have anything credible or smart to say... STFU
Old Aug 29, 2005 | 04:32 PM
FModFTD's Avatar
Ok, on a serious note, if the fluid level is at half, there may be a leak somewhere. Check for wet hoses, puddles, or other signs of leaks. (Then check your car Sorry, I couldn't resist.)
Old Aug 29, 2005 | 04:33 PM
mandos's Avatar
Uhh...Uhh...I think I have a headache now.
Old Aug 29, 2005 | 05:52 PM
haha nice :D
well, aside from the usual brake dust on my rims, there often is some kind of visible liquid that was once on there, that also caked on, and I've always attributed that to brake fluid. I should have guessed it had to come out of somewhere, right? I'm not sure if it's normal to leak out like that occasionally.
otherwise, no leaks or wet hoses
Old Aug 29, 2005 | 06:13 PM
hahaitzskippy's Avatar
well my brake line is perfect. and fluid levels are at max.
for me it started about 35k miles and im now at 37k miles
started off as only turned on during hard accel in 1st.
then it went to 2nd.
then casual driving in 1st, then in 2nd, now in 3rd. and little in 4th.
haha i think its teh sensor. i havent taken it in to get it fixed but i dont relaly think its a problem.
Old Aug 29, 2005 | 06:19 PM
Brent_23M's Avatar
switch to steel brake lines, prolly not even related but i suggest this to everyone, more precise controll and less chance of leaking brake lines
Old Aug 29, 2005 | 06:42 PM
yeah with my next brake pad change im going to actually do goodridge SS lines and porterfield pads. 200 bucks well spent. so the system will get flushed anyway, but im going to go ahead and refill it today.
