engine swapping the end all
Old Aug 29, 2005 | 02:39 AM
whtmvsu's Avatar
Default engine swapping the end all
Although I am happy with my 1nz (xB) I was wondering if anyone swapped the motor from their xA or xB. I'll try to do some research on this besides what I have done already but if anyone can contribute let me know let make this the end all on engine swapping since the serach function shows many conflicting issures on this.
*1nz to 1zz is possible some say tranny will bolt up some say it doesn't
*I am sure 2zz would bolt up simlar to 1zz but want to make sure some think torque is better with 1zz trd sc setup rather than 2zz but if you want na then try the 2zz (Lift rocks)
*No clue on the 1nz to 1az bolting up (will up date)
And no don't think about the supra bolting up to anything without considering serious engine bay mods.
buddy is attempting a 1nz(echo) to v6 swap from tacoma keep you posted
Old Aug 29, 2005 | 03:23 AM
05-RS1's Avatar
lol an echo wit a v6?! sounds wild!..so much for gas mileage eh?
Old Aug 29, 2005 | 03:25 AM
Max's Avatar
Max
Start your searching here, it's been discussed way to much. Search button's at the top.
Old Aug 29, 2005 | 01:24 PM
chucksu's Avatar
https://www.scionlife.com/forums/vie...ht=engine+swap
the only finished engine swap
Yes the 2ZZ-FE engine has been slammed into a Vitz by a UK company. As for a V6, I could see it if the thing was a 60* or less, if its a 90* V6, I see the block being to wide for this engine bay.
Old Aug 29, 2005 | 05:21 PM
hotbox05's Avatar
for the 1zz you will need to use the 1zz 5speed. at least from what i'm told. a 2zz 6speed will be huge and you will have to cut even more.
people have swapped 4efte's
someone is sure to swap a 4age/ze within a year or so
someone is sure to try and swap in a 3sgte
Old Aug 29, 2005 | 08:35 PM
jwa276's Avatar
yeah the 3s is a decently small block, and the 3sgte has a huge range of options as far as aftermarket goes (along with the 4ag[z]e). correct me if im wrong, but dont some of the jdm 3sg[t]e's pack vvti in some of the altezzas?
-jon
Old Aug 29, 2005 | 08:41 PM
hotbox05's Avatar
yes i believe the altezza's did have vvti or vvtli. but..... 3sgte's are very very expensive motors. damned yamaha.
JonathonK
Mar 22, 2018 09:00 AM
churrosurf
Jan 30, 2015 01:12 PM
tbblizzard
11
Dec 5, 2003 12:21 AM
toyotaisme
13
Nov 14, 2003 01:37 PM
Torokun
21
Sep 25, 2003 03:02 PM
