question about cold engine light
Old Aug 31, 2005 | 04:34 AM
xB_Shiftin's Avatar
Default question about cold engine light
are you supposed to wait til the blue light turns off before driving it? Or can you just take it easy for the first mile or two until the light turns off?
Old Aug 31, 2005 | 09:56 AM
SciFly's Avatar
You should drive as soon as it's running.
The quicker the engine warms up the longer it will last in service
The blue light tells "cold". The engine managament computer locks the automatic
OUT of fourth gear, to speed the warm-up process by forcing revs.
When an engine is cold it's working clearances are large and ample and there is no risk of oil starvation with modern multi-vis oils. Therefore, there's no reason to baby the engine just to warm it up.
The major cause of cylinder bore wear is corrosion caused by the condensation of moisture on cold cylinder walls. This water comes from the combustion process.
It is nothing more than -rust- in micro thin form. By running the engine under load ASAP after starting this period of engine wear is shortened to a minimum.
Modern oils are really good at minimizing corrosion wear, but still, it's best that we not coddle a cold engine. Run it up to temp by driving it as if it were warm.
reid
Old Aug 31, 2005 | 10:56 AM
chucksu's Avatar
^^ Just like he said. Just take it easy when the light is on ie: no WOT take offs & keep it under 2.5krpm. Doing this, should take about 1-2min or 1 mile to get the light to go off.
Old Aug 31, 2005 | 12:42 PM
xB_Shiftin's Avatar
cool, great advise and it makes sense. I definitely havent been waiting for the light to go off everytime but I have noticed that the light goes off faster when I just drive it before the light goes off. What I dont understand now is what is that light displayed for if it doesnt have any effect on how you should drive it? shouldnt we only be worried about it overheating (red light)?
Sorry for all the stupid questions
Old Aug 31, 2005 | 01:13 PM
Max's Avatar
Max
Well, it varies greatly depending on outside temperature. When it gets somewhere around freezing, it'll take several minutes.
The light will go off sooner when you drive it. This is because you are running the engine faster=more explosions=more heat=warmer engine sooner. I am not sure why the blue light is there, other than possibly explaining to the driver why the car won't shift.
My red temp light has never come on (except for startup) and I am not worried about it doing so.
One thing that hasn't been mentioned, is that third gear is locked out until a certain temp is reached just like fourth. You'll notice this when it gets colder, and yes, it's annoying.
Old Aug 31, 2005 | 01:15 PM
xB_Shiftin's Avatar
i got a 5 speed
Old Aug 31, 2005 | 01:48 PM
Fujiz_xb's Avatar
sIcKsCiOnS
makes sense.thanks for the answers.the fuji learned something new.
Old Aug 31, 2005 | 04:42 PM
bB626's Avatar
yeah, thanks guys, i learn something new too. i've been wondering the same thing.
Old Aug 31, 2005 | 05:23 PM
PaganGuy's Avatar
I think the light will turn off at 158 degrees, so it will take longer in colder weather. I live in MI and sometimes it would take many miles to go out.
Old Sep 1, 2005 | 04:13 AM
SuperToaster's Avatar
I hate that little blue light. Scared me the first time I saw it. It is the first car I have seen that has a "warning" light when it is cold. LOL Just one more thing to worry about.......
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
hotroddelux
Dec 3, 2014 11:33 PM
