View Poll Results: what do you think is better
Voters: 23. You may not vote on this poll
what do you think is better turbos or superchargers
what do you think is better please explain why
there are turbos and superchargers that produce teh same amount of boost what would you buy plaease explain
Get rocket propulsion, I hear that the space ship has around one million HP or so.
Or you could use the search button and stop asking question that have been answreed a million times over.
just my pref, but i like SC a little better simply becasue i want the power there right from the get go. i dont want to wait around for my boost to hit. Granted turbo lag isnt all that noticable, but you still have to wait a little bit for it to start spinning. im sure there are plenty of people that like turbo's better, i like the sound they make when they hit. but i personally dont like to wait for my power, im inpatient.
Who cares? As of right now there are ZERO options (turbo or s/c) on the market. Automotive technology has increased so much that both options produce almost identical results. Turbo lag is not really even an issue anymore unless you're spooling a huge turbo. Why not just wait till there are several different options available (with dynos and times) so you can make an informed decision instead of just debating over which one is better.
Have you EVER Driven a turbo car? Impatient? more like uninformed, get your facts straight, you make it sound like you have to sit down and wait for the turbo to spool for like 3 hours. COME ON, for a SC you have to wait ANYWAYS for the belt to produce enough boost to go in. It isnt THAT instant my friend.
I prefer a turbo because that makes the most sense, mechanically. Specifically, a turbo is basically being over 100% efficient the cost of making power is effectively 0.
However, that's just academic stuff as I've never driven in a turbo'd vehicle.
I have driven a supercharged vehicle and the power delivery is very smooth. When they say "there's no replacement for displacement" I'd have to respond that a supercharger (centrifugal) is the best replacement for displacement as it really makes the engine seem a lot larger. It's kind of like supercharging a Civic would be akin to driving a v6 Accord's engine.. kind of
Miconceptions:
SC do not exhibit lag.... not true for a centrifugal SC. It is not quite as bad as a comparable turbo in many cases, but still there.
Turbos are not parasitic... correct, they are resistive. They still add resistance to the exaust flow (not as bad as the load a sc adds to the drive system). But they are far from "free" energy (no such thing) .
As far as which is better, there are a million things to consider before you can make that decision. As always application and need makes a huge difference. Try searching here and elsewhere, learning all you can about each, then determine what you want and the type of driving you are doing and then decide. It is not as simple as which one is better across the board. For most street driven, "I want a lot of power for my money for average driving" cars turbo is a good way to go.
turbo's don't use power to make power... they may cause "resistance to the exhaust flow" but they do not steal power to make power.
thanks for your answers but
whats wrong with you thomasabin if a person asks a question that you don't like don't answer you don't need to flame them
and mebbe a lil bit of this
also i am asking what people would prefere i already know all about turbos and sc and how they work
as engifiner said....
the law of conservation of energy... it takes energy to make energy, but in the process, some energy is unused, not lost. it can change to a different state, whether it be gas, liquid, or soild..
you two are reading way into this. you're getting into law's of physics... there's no crank driven shaft spinning a turbo to make it create boost. it works like a windmill. the wind is already there it just puts itself in the way of it to spin the turbine.
go all einstein you want but the supercharger takes a larger amount of power to create it's power.
if you want to argue, run a supercharger at 10psi and a turbo at 10psi and see how much of a huge difference in power there is
we are not arguing that.
you said "turbo's don't use power to make power"
replace power with energy... because that is what it is
we are simply saying a turbo does use energy to make energy
conservation of energy is deff not looking too deep into it at all... thats actually on the surface
The point they're making is that a turbo is NOT FREE energy as that is impossible. In your case of a windmill, kinetic energy of the wind is converted to mechanical energy and thus that energy did not come from nowhere, obviously. But the speed of the wind is hampered by the blades of the windmill.
It's the same in a turbo. A turbo is basically a useful muffler. While in lag, most turbo'd cars perform less than a car that is not turbo'd at the same rpm because the exhaust is restrictive. It's like that valve in the stock muffler - it opens and closes based on exhaust flow and is an impediment to flow.
Your point, matty-tc, is simply that a turbo robs less power and makes more than a supercharger which all these academic types are also saying. Engineers and students of physics and just overall smarties like to argue over such things as the existence of free energy.
OT but isn't this nicer? To lightly pounce on people for calling a turbo a source of free energy instead of jumping someone for calling the header in a tC "headers"? How infinitely more academic this is..
In anycase, for those people who say streetable turbos really don't have excessive lag - C&D calls the WRX turbo "wait 'til tomorrow turbo lag." I felt that was reasonably amusing.
Edit: instaposted, blast!
Edit: I'm such a nerd..
Well, since the laws of physics apply to EVERYTHING, then why not bring them up? Initially matty said it does not take power to make power which is IMPOSSIBLE!
Whether you push or pull a car, your body uses energy to move it... same with an engine. Whether it "pulls" (sc) or "pushes" (turbo) it is wasting some power. The engine can tell no difference between the two. The crank is either slowed by a parasitic connection to the belt or by a restriction to its movement in its exhaust port. Yes, spinning a turbo is more efficient. But the overall effect is some wasted power, period, no way around it. You can call out the laws of physics (which most high schoolers know, not just us "smarty" people) or say it more simply.. but however you look at it they both take power to make power, one just wastes a little less. It has nothign to do with some theoretical discussion of free energy, it is simple cut and dry physics.
You can argue that a turbo is more efficient, yes, but saying it wastes no power is so far from correct it is ridiculous. If you find one that doesnt.. you will be the richest man alive
Good post...... you nerd
