View Full Version : installed 1 set of NF210's and TRD dampers and NOW w/pics!!!
jct
09-03-2005, 04:23 PM
working on lowering my car
got the new springs on
while working on the front struts got every thing back on i cannot get the nut tightened/torqued down to 25lbs when i try the shaft is rotating with the nut how do i get the shaft not to rotate??? this is the only thing that is holding me up!!!
chucksu
09-03-2005, 04:36 PM
http://www.scionlife.com/forums/viewtopic.php?t=20769 Might help you out some. Its on a xB, but same difference pretty much.
jct
09-03-2005, 10:46 PM
they say around 3 hours but it took me 8 hours to do it all :shock: had to visit the shop at work then i forgot the nylon lock nut at home so i had to go get that
gonna get pics very soon
its going in tuesday 090605 to get a 4 wheel alignment done for 69.95 at the dealership + tax
i just want to thank chucksu and randode for all there help
chucksu
09-03-2005, 11:45 PM
:silly: No need to thank me. I just found a topic that could have had info that helped you out. Cant wait to see the pics :bow: My main question in this case. What is the torque raiting is for the 3 bolts that hold the front strut in place? My dang strut bar came with no instructions, so I have no clue what to torque them to when I install it.
Newtmaker
09-03-2005, 11:57 PM
29 foot lbs according to the manual.
Walt
jct
29 ft lbs
haha jinx :silly:
to make things easier on your self remove the cowl doing so makes the job so much easier to torque down
uber-xA-RS2
09-04-2005, 12:46 AM
Ahhh, yes the challenge of the front struts. They were rather tricky when I put them in as they didn't want to go back together. Nice to see that you got them back in. :D
jct
09-04-2005, 01:11 AM
i had to remove the swaybar end links to get 'em back in
i had some real fun doing the rears with one of my jacks flying all over the place :shock: :lol: it didn't like the what i was using it as
i was planning on doing it after work glad i didn't!!!
it was the best 8 hours ever spent wasn't even bored :silly:
xB_Nutt
09-04-2005, 02:33 AM
If I were you I wouldn't get it aligned for a few weeks so the springs have a chance to settle to their final position...
rebelMan
09-04-2005, 03:35 AM
Yea i would wait too, although, i waited for a few weeks, never got alignment, changed springs, never got an alignment since, and yesterday put stock springs on so i'm glad i didn't get an alignment....but i'm trading it in so thats why (echo for xB, hopefully)
uber-xA-RS2
09-04-2005, 04:06 AM
I'm curious, got any pics of the NF210's yet? I have the DF210's but I'm curious to see the "other" Tanabe's on an xA. :ponder:
SciFly
09-04-2005, 04:12 AM
Use an air or electric impact wrench. Learn its characteristics and ADJUST it so it does not apply too much torque to the nut. This is easy to manage. An impact wrench is a near-must when working on a modern car. Used intellgently it is no risk, despite the dire warnings from our parts manufactureres, who WORRY about the idiot factor :P
sidebar: torque, as applied to very short "bolts" like the threaded end of a strut damper, is a misunderstood value. Make the nut tight. Make it tight enough that it won't work loose. For -real security- simply apply a second nut on top of the first. And with the impact wrench, settle that down firm -but not killer- onto the main nut.
We simply want to keep the parts firmly together. You all get the concept? Tight is together. MORE tight than that is merely inviting problems.
Mark what I'm saying: this particular advice is truly applicable to short bolts, or threaded-in full depth bolts. LONG bolts, nutted opposite the clamped assembly DO benefit by relatively precise torque specs. Why? Well, this gets into elastic deformation of the longer bolts' lengths. This s-t-r-e-t-c-h works to maintain clamping tension.
In short studs, however, there is very little elastic action. Ergo, no need to super-torque. Torque wrench specs in such cases are, IMO, a cause of much worry. Make the parts hand-wrench tight in most cases. Most but not all...
Some native intuition is needed to be a good mechanic. There is no substitute for hands-on experience.
hope this helped,
Reid
PS: Hornet, the way an impact wrench works is by abrupt, small shocks. This -hammers- the fastener without spinning the damper rod. It all works by inertia vs. frequency and force. In the olden days a master mechanic would've solved your problem with a hammer applied to the end of a six point socket wrench's non-ratcheting handle. Same principle.
sidebar further: My first lesson from a master mechanic came when I was 19, in 1973. My mentor was an old man who loved mechanics ever since he began working as a pro in the year 1920. He was a volunteer helper at the Charleston Navy Base auto hobby shop for enlisted men.
I could not get a rounded-off wheel lug nut to budge from my old 190SL. He stepped up. Sick old guy then with dropsy and fading eyes behind coke bottle glasses. I see him again:
He picks out a cold chisel from the work bench. He kneels down on rheumatic knees, with a big hammer and this chisel... and with two strikes he's bitten a grip for the chisel, into the flanged edge of the lug nut.
Two more strikes, heavier, and the nut spins free.
He looks up at me and smiles. And he knows by the astonished look in my young eyes.... that his life had not been played out on mere cars to end for nothing.
He knew I'd never forget him for this favor and lesson in -learning your tools and materials-.
He was dead soon afterwards. But not really gone. You see?
jct
09-04-2005, 04:52 AM
thats why i went to the shop at work he has a air impact wrench that is capable of doing a 1000 ft lbs
i tried using the electric impact it just isn't as powerful at a air impact
i did manage to get the nut torqued to spec
jct
09-04-2005, 09:30 PM
added a 2 day pole. vote vote vote right away !!!
rebelMan
09-04-2005, 11:43 PM
you can't hurt to wait, but you might have to get it aligned again in the near future IF you get it aligned right away.
andrewjc
09-05-2005, 12:31 AM
Those springs are on my short list. I can't wait for the pictures!
jct
09-05-2005, 12:49 AM
sorry no before pics, just after pics
if they don't load right click and click view image
god i hope they load!!! :shock: :silly:
if not here ya go http://www.imagestation.com/album/?id=2121230275
http://www.imagestation.com/picture/sraid185/p3b50b3edb679515609890ba2ec705cac/f279c694.jpg
http://www.imagestation.com/picture/sraid185/pa164d22cc30f31c108a01773d6f8938f/f279c62c.jpg
http://www.imagestation.com/picture/sraid185/p38d5cefd6a2ccb676e1f1eb957d92caa/f279c5cf.jpg
http://www.imagestation.com/picture/sraid185/pa9f75029b3edd4f8f5f46e2f1101d2fd/f279c562.jpg
http://www.imagestation.com/picture/sraid185/p4a290c9a540e10291f146eeae877f8d8/f279c4ec.jpg
too it out for a short drive hit all the dang road imperfections i could find didn't make one creak and i couldn't even feel the bump with the rear tires (you know you can hear the bump bump, its just the bump now i need a back seat passenger too tell me now lol)
i like it well worth the all the money and all that 8 hours well spent on the install very pleased!!!
it handles just fine
andrewjc
09-05-2005, 11:09 PM
Thanks for the pics. Your xA is looking sweet! Please comment more on how the ride has changed. I would hope with the softer rates in the rear the car would ride a lot better. Also does the rear of the car sit lower than the front? It looks fine from the pictures, but just wondering what it looks like in person. Thanks again...
jct
09-06-2005, 01:25 AM
i took a ruler too it tonight and the rears have a "gap" around 2 inches and the front "gap" is about 2.5 inches
like i said i took it over all the roads. smooth roads. country roads (with a bunch of road imperfections). and on the highway
i like my set up very well :)
uber-xA-RS2
09-06-2005, 09:06 PM
Wle some of the images didn't load here on SL I took a look at imagestation. The results are quite impressive for a medium size drop. Now you just need some wheels and you'll be golden. :silly:
jct
09-06-2005, 11:25 PM
heres the rims i want
http://www.scionlife.com/forums/viewtopic.php?t=80285
too bad they don't make it in 15 inch rims :( :?
chucksu
09-06-2005, 11:30 PM
That is different. My question though, does it even come in a 4x100 bolt pattern?
jct
09-07-2005, 11:38 PM
well i'm happy now that my suspension work is compleat :)
8 months later :silly: not bad really
just check out my profile
next year i'm finishing my power mods and installing slotted rotors
Buebie
09-07-2005, 11:51 PM
LOL @ 8 hours. How many beers did you consume while doing it...be honest :p
We had an air compressor, so it only took about 30 minutes. But if I was doing it bymyself it woulda taken all dam day...without drinking heh.
jct
09-08-2005, 12:10 AM
i don't drink i find it a waste of money, i use that money on my car ;)
but i did drink a lot of water and had to come and check my shop manual many many times to study it to see how the funk they do it lol and studied the online DIY'er sites and threads some of the threads i didn't even know about :shock: oh well its all back together now and the most important thing is, its still driveable :silly:
cadaver
09-08-2005, 03:22 AM
your car is looking awesome. what height drop were those springs? im looking to do approx. 1.75 to 2 but dont want alot of drop. also, where did you get the spacers and how much. as far as your wheels, go to www.americanracing.com, they have a ste almost identical to what youre looking for only they are five spoke. however, they do offer them in 15x7, 4x100 size. i know i looked at these as possibles for my car.
jct
09-08-2005, 03:40 AM
1.3 (1-5/16th) inches in front and inch for the rear
SciFly
09-08-2005, 03:44 AM
a fine lookin' slipper for the big tall Gipper
you did good. all the pics loaded fast and easy here on dialup.
kudos and have a glass of ice water on me.
brrrrrr! damn! i did not mean you to pour it down my neck! brrrrr! damn'ornet! :rofl:
jct
09-08-2005, 11:34 AM
i like to make my pictures 56k friendly :)
