Rims and fuel economy
Old Sep 4, 2005 | 08:39 PM
augiAUDIO's Avatar
Default Rims and fuel economy
Will 17 inch rims decrease my fuel economy?
Old Sep 4, 2005 | 08:51 PM
FModFTD's Avatar
If the tire is wider than stock, then yes, but not by much.
If the tire is a larger diameter, the mileage will get better--if it's smaller, the mileage will get worse. But you won't see it, since the odometer will be out of calibration.
If the wheel is heavier than stock, the power will be a bit less for accelerating, and the mileage may go down slightly, but not much.
Old Sep 4, 2005 | 09:07 PM
gaffman's Avatar
If the tire diameter is larger you will lose low end power (acceleration) how much depands on how much over the stock size you go
Old Sep 4, 2005 | 09:08 PM
Max2k's Avatar
heavier anything=less mpg
Old Sep 4, 2005 | 09:12 PM
Subcompact Culture's Avatar
I have 18s and get about 1.5 mpg less than with the OEM steelies.
Old Sep 4, 2005 | 09:44 PM
Mosh_xB's Avatar
what size are the OEM steelies/caps?
i want rims, but i dont want to go too big or too small
Old Sep 4, 2005 | 10:04 PM
gaffman's Avatar
Are you sure you are getting less MPG? Depending on tire size: Did you take into consideration your odometer error with the taller tires?
Old Sep 5, 2005 | 04:14 PM
maverick1's Avatar
I have 20's and just got 31.5 mpg on my last fill up. All city driving with AC on, and auto tranny. I also calculate for the difference in my odometer for the larger wheels. Key to good milage I found is to not floor it when I take off, and let it shift at 3000 rpm's or below.
Mav
Old Sep 5, 2005 | 04:32 PM
Well, a 185/60/15 vs. a 215/35/18 is 0.8% difference. That's not much at all. I can't imagine that'd impact my actual MPG much if at all.
Old Sep 6, 2005 | 01:32 AM
Surfmobile's Avatar
what about road noise? That's my main concern...
Jun 2, 2015 03:36 AM
ScionLife Editor
Apr 1, 2015 11:10 PM
XDC
Feb 1, 2015 11:56 PM
DjFrOsT
15
Jan 17, 2004 12:20 AM
Risen_Son_Racing
Oct 12, 2003 01:21 AM
