bluxb
10-15-2003, 08:23 PM
where did you guys ground your amps at? i just grounded mine at one of the bolts that hold the backseat down but i am getting some interference. any help would be appreciated
View Full Version : ground for amp bluxb 10-15-2003, 08:23 PM where did you guys ground your amps at? i just grounded mine at one of the bolts that hold the backseat down but i am getting some interference. any help would be appreciated mypursuit 10-15-2003, 08:30 PM pop up the center console thingy...wala...there is plenty of sheet metal to choose from... eric_m 10-15-2003, 10:25 PM i grounded mine to where the seat bolts to the frame. just make sure you ground it to something with no paint on it or you will get a bad ground and some fun noise when you rev your engine. wheeeeeeeee!!!! oh, also make sure the ground wire is as short as possible. also, keep your RCAs away from all power wires. ok enough lecturing from me. sorry. ItsMrWells 10-16-2003, 03:58 AM i install car stereos and the shorter your ground the better. just find a spot under the carpit in the back to ground it like in a corner or something. when i get mine ill show you where im going to ground it |
