Hotchkis Sway Problem
Old Sep 6, 2005 | 12:44 AM
-Keith-'s Avatar
Default Hotchkis Sway Problem
Ok I saw a guy posted this along time ago. Well I thought I took the proper precautions and did it right centered it from a even point and so on... Well after 3 autox's later and alot of aggresive driving, here is my problem.
**Sorry some are blury**
Driver side
http://72.41.41.139/images/swayproblems/IMG_1041.JPG
Passenger Side
http://72.41.41.139/images/swayproblems/IMG_1050.JPG
For additional pics check out the directory... http://72.41.41.139/images/swayproblems/
Now I torqued em down good had it centered and still it moved to the one side. I dont know if it is cuz the car is so low or what. Any suggestions im gonna be in contact with hotchkis soon.
Old Sep 6, 2005 | 04:13 AM
The_Instigator's Avatar
direct links dont work. might want to resize those, they take forever to look at and Im on a 6Mbit line. Cant really see whats going on when theyre that big.
Old Sep 6, 2005 | 04:48 AM
SSM_tC's Avatar
The Direct links don't work, but the Directory does.
Didn't take m elong at all to DL each, 3 secs tops... and Auto-Resize is my friend.
Whole Lotta Rubbing going on there, Keith, not cool. Hopefully one of our fellow members or Hotchkis can help you out. Good Luck
Old Sep 6, 2005 | 05:03 AM
-Keith-'s Avatar
yea did u notice driver side is almost hitting the bottom and the passenger side is like 2 plus inches away from hitting
Old Sep 6, 2005 | 05:04 AM
-Keith-'s Avatar
links work now.
Old Sep 6, 2005 | 05:30 AM
SSM_tC's Avatar
Yup.. that sucker looks all chewed up
Old Sep 6, 2005 | 05:47 AM
-Keith-'s Avatar
ive rattled my brain enough this weekend over it. car still sits straight but that things just not right
Old Sep 6, 2005 | 07:31 AM
lo_bux_racer's Avatar
Your pics made me curious. I just checked mine, they look worse than yours. The tie rod has a lip on it (visible in your shots) that is scraping on the outside of the bar. This doesn't happen at full droop, and I didn't investigate exactly where it does right now (will do this tomorrow on my vacation day). I also discovered the bar is getting chewed on the passenger's side by the subframe, even after pushing the bushing all the way back to be sure it cleared (I did check this on the install by using a jack to work the suspension with the car completely suspended on jackstands). It appears either we both botched the install, or Hotchkis needs to address this as a problem.
Old Sep 6, 2005 | 12:23 PM
-Keith-'s Avatar
I did the same made sure the bushing was pushed all the way back to give maxime clearance
Old Sep 6, 2005 | 09:06 PM
Did you use the slotted mount for the front or rear? I reread the instructions last night and combed them for anything I might have done wrong and discovered that they want the slotted mount on the rear. I have mine in the front. Unfortunately, there is no picture showing which is which until the last page of the instructions for the rear bar. It clearly indicates the slotted one goes in back. I'm changing mine today in hopes of making a difference.
I'm not especially impressed that Hotchkis called out the part for the front by part number but didn't put the part numbers on the part and didn't include a picture to ensure you got the right mount in the right place. I sincerely hope it makes a difference..
Old Sep 6, 2005 | 11:56 PM
-Keith-'s Avatar
Uhh you cant mix em up they wont fit....
Old Sep 7, 2005 | 01:16 AM
Complication's Avatar
well thats no good... sorry to hear your probs guys, whats just as bad is I just ordered my set today.... I'll let you know how the install goes on friday... goodluck guys and I hope this isn't a trend!!!
Old Sep 7, 2005 | 01:20 AM
-Keith-'s Avatar
who you order through and how much? trying to see where my prices compare...
Hotchkis is talking to me they think it might be because of how low the car is.... if thats the case alot of people on here gonna have some problems
Old Sep 7, 2005 | 01:50 AM
danman04x's Avatar
i have tein s techs and have the rear bar installed but am waiting to get the front done professionally. does this mean i shouldnt even put the front on now?
Old Sep 7, 2005 | 02:23 AM
-Keith-'s Avatar
no do it
its a wonderful bar...
Im not saying theres anything wrong with the bar in my app somthings wrong. Could be my fault.... I was seeing who else had the problem.
Old Sep 7, 2005 | 02:31 AM
DTRUONG_112's Avatar
I waiting to put mine on too.
Old Sep 7, 2005 | 02:35 AM
dex's Avatar
dex
im actually surprised noone has noticed this before. it has nothing to do with the bar being centered and everything to do with the car being lower than stock. the tierod hits the swaybar when the steering wheel is turned to lock. my mechanic tried to get in contact with hotchkis but to no avail. they apparently dont want to deal with the problem. ive brain stormed it and the only solution i can think of is to put a spacer between the mounts and the chassis and then shorten the end links. i would suggest having someone help you find out how far you have to turn the wheel b4 the tierod makes contact and to avoid turning the wheel that far unless need be.
Old Sep 7, 2005 | 02:39 AM
-Keith-'s Avatar
sounds like the fix is shorter end links... aka hotchkis needs to make em and give em to those having the problem
Old Sep 7, 2005 | 02:44 AM
I got mine at an amazing price from http://www.mcgeorgeparts.com/ for $240 shipped! if you pick it up its like $219
btw how lower is your car?
Old Sep 7, 2005 | 02:50 AM
dex's Avatar
dex
and like keith said. these bars are amazing...i have no plans to remove them because of some rubbing. the stock front bar wasnt tubular on the ends like the hotchkis bar is and i have a feeling this is why. but it is really annoying and im hoping hotchkis mans up to it and solves the problem. being a race oriented company i know they got to expect you to lower the ride height to increase the cars stability.
