Greddy E-Manage
Old Sep 7, 2005 | 11:24 PM
purpleHaze's Avatar
Default Greddy E-Manage
Has anyone installed the e-Manage? If so, how hard was it to tune and what kind of improvements did you experience. Thanks!
Can the original E-Manage remove the speed limiter and up the rev limiter. I dont have that much experience in the electronic tuning aspect so any info is very helpful. Thanks again!
Old Sep 9, 2005 | 03:55 AM
miamiBASS's Avatar
i would like to know also..
anyone?
Old Sep 9, 2005 | 04:27 AM
WFOTC's Avatar
don't know much about emanage on scions; but, I have delt with it on srt4s and NO it doesn't remove the rev and speed limiters as it is only a piggy back. Also, I would imagine that it wouldn't really help that much with a stock or minor bolt on n/a car. Lastly, I think Zpi and another vendor include emanange in their turbo kits so Iam sure they can help.
Old Sep 9, 2005 | 05:49 AM
-Keith-'s Avatar
you need the ulitame one.. it will do what u want
Old Sep 9, 2005 | 01:15 PM
matty-tC's Avatar
it can remove the rev limiter i believe... not sure about the speed limiter but you don't need to remove the speed limiter.
expect about 5-10whp for tuning your car with the emanage
Old Sep 9, 2005 | 01:30 PM
TurboCustomz's Avatar
The standard emanage will NOT remove the speed limiter or change the rpm limiter. YOu have to buy the ultimate if you want those features.
Old Sep 9, 2005 | 01:35 PM
Munch's Avatar
This is correct.
Old Sep 9, 2005 | 02:37 PM
Simplyscion's Avatar
Team No Limitz
Until your long term fuel trim kicks in and cuts you off, then it wont do sh*t and its time to unhook the battery cable and start all over...closed loop is pretty hurt guys. Thats why im buggin out a lil bit over these turbo kits from dezod and zpi...piggy back is a band aid, it will stick to ya for a few days, but after a lil bit of use it wears off and its time for a new one.
Old Sep 9, 2005 | 02:48 PM
jmiller20874's Avatar
^^^ eManage only works for a few days? Confused.
Old Sep 9, 2005 | 03:10 PM
raamaudio's Avatar
Hmmmm, I ran 13PSI, 250WHP on our Matrix and all we had was the stock ECU, aux fuel injector and a D2 aquamist that was metered by reading the aux fuel injector. After the final tune it ran great for many thousands of miles, all hard core use except some crusing on the way to autocrosses, a few drags, etc. Now it is back to NA with over 50k miles and does not use a drop of oil, runs perfectly fine.
Not so sure there is going to be a problem but here is a little trick in case there is. I forget which pin in a particular but a toggle switch on the dash can be flipped to off when you park the car and on when you get back in, once a day, every couple of days, several times a day, etc, resetting the ECU, no more problem;)
Rick
Old Sep 9, 2005 | 03:25 PM
Team No Limitz
When using aux injectors you are overiding the stock ecu being that there is no way to interrupt the extra fuel going into the intake mani. I have that for my car, its pretty much the only way besides for standalone to make it run good, but thats a really good idea having that toggle switch...I should look into that.
Old Sep 9, 2005 | 03:37 PM
slammed's Avatar
im a little confused. Is everyone having this problem that has zpi stage 0?
The emanage holds its tune despite the battery disconnect?
Old Sep 9, 2005 | 03:48 PM
Team No Limitz
looks like I stirred some sh#t up...sorry guys...but the honest truth is that in a closed loop, regardless of piggy back or not the long term fuel trim will readjust against any settings that you have for the emanage, SAFC, Turbo XS Game boy junk, Camcon, etc(not true for all closed loop ECU, just toyota and a few others). As I and raamaudio said before, aux injectors is the answer to this solution because the computer isnt in control of the extra fuel thats put into the intake mani, you are. Even if the MAF sensor is buggin out, its still getting fuel and is getting tricked back into running normal.
raamaudio's Avatar
Not sure on the emanage but I imagine it has an EPROM or similar to hold the programming with or without power.
Even if it did lose it you can eliminate that with the toggle switch mentioned above, just reset the ECU, power stays on for the Emanage.
Anybody have a reason this will not effectively cure the problem???
Nothing stirred up here See, all happy
Rick
Old Sep 9, 2005 | 03:54 PM
Team No Limitz
I know that even the Camcon holds its settings even when disconnected or when battey cable removed or ECU reset...im gonna definitely try that switch and see what happens
Old Sep 9, 2005 | 04:00 PM
matty-tC's Avatar
have you seen the AFR on a stock tC? it's very close to FI friendly. If i remember correctly it was 12.5-12.7:1 throughout. If it trims the fuel back to this, then it's still going to be somewhat safe. Personally I'd rather see a 11.5:1 but with the strength of the 2az-fe, i woudln't worry too much.
i'm confused about one thing though... with the injector harness on the emanage, wouldn't this completely control the width/duration of the injector pulse?
Old Sep 9, 2005 | 04:18 PM
Team No Limitz
Dam, thats sick I think on my car its around 14 range. I cant wait to get one now and boost it. The 2az is a real strong motor. I think as far as the injector harness, the MAF readings will still overrule and limp out. Havent tried the emanage yet so I could be wrong. Our factory ECU's might just be too smart.
Old Sep 9, 2005 | 04:20 PM
matty-tC's Avatar
it'll be interesting to see if the TURD s/c includes a reflash. if not then I could see lower boost being fine with a standard piggyback.
Old Sep 9, 2005 | 04:31 PM
Team No Limitz
supposed to come w/ injectors...I dont know how they would reflash our computers cause I just dont think its possible at this point yet. Its probly a bigger fuel pump and regulator w/ injectors and a black box.
Old Sep 9, 2005 | 04:34 PM
aarontrini85's Avatar
if that is the case then we will just have to kill them its us or them the smartest servives lol are there any companys that do reflashes for the ecu the 2az uses???? maybe i should ask on a camery forum
