sidewall height
Old Sep 9, 2005 | 07:58 AM
Kilo6_one's Avatar
Default sidewall height
ive noticed different brands have differnt sidewall hieghts........im looking for the lowest profile on a 225/40 18 tire.....pics are helpfull, i have a tein Htech drop about 1.7 inches. id like any helpfull input, i really dont want to have to go to a 215/35-18 or a 225/35-18.
Old Sep 9, 2005 | 08:11 AM
daewonder's Avatar
you mean, not all 40 series tires are the same height? hmmm.
Old Sep 9, 2005 | 08:17 AM
Kilo6_one's Avatar
yeah, some ive noticed are different height.......kuhmos are the worst,good tires, ive had them, but thier sidewall is higher then others. ive narrowed it down to falkens, bfgoodrich or nittos. im looking for a good all around tires wet and dry traction.
Old Sep 9, 2005 | 10:35 AM
lo_bux_racer's Avatar
Got measurements to support that claim? Tire sizing is controlled by DOT. It would be really bad for a manufacturer to claim the tire is a size that isn't the same as the other manufacturers. Tread width can vary, but overall carcass width and aspect ratio are not up for interpretation.
Old Sep 9, 2005 | 04:31 PM
Kilo6_one's Avatar
i already know that, but some tires appear to look shorter then others, that is what i ment and should have clairified that in my first statement
........some of you guys take everything too literal, like im off to sue someone and im looking for "facts to support my case" . relax. its a personal observation that i have noticed lately about tires..........so settle down
Old Sep 9, 2005 | 04:50 PM
HKSpeed's Avatar
tires with the same width, aspect ratio and diameter should all be the same size. i've never seen a one tire look taller than another with the same size specs. thats like saying some 17" wheels are taller than other 17" wheels (of the same width). maybe youre comparing a tire with more tread and one with less tread. or you could be looking at a tire thats been stretched to fit a wider wheel, which does thin the appearance of the sidewall.
certain wheel designs can make tires look fatter or thinner. to me, thin/narrow spoked wheels make tires look fatter than thicker spoked wheels.
Old Sep 9, 2005 | 05:00 PM
Kilo6_one's Avatar
yeah, i started to think about the stretched thing too..........your right about the certain wheel designs as well. well off to the tire shop to look at different tires.
Old Sep 9, 2005 | 05:42 PM
maverick1's Avatar
I have Nitto's, and I love them. Not a bad of a ride either for low profile tires.
Mav
Old Sep 9, 2005 | 06:08 PM
Kilo6_one's Avatar
i had nittos before, i really liked them.......
Old Sep 12, 2005 | 05:18 AM
DuMa's Avatar
FYI, the middle number indicates the percentage of the tread width that is the sidewall height. it is not a set number or 'series' so not all 40 series are the same height. it can vary
Old Sep 12, 2005 | 05:39 AM
Kilo6_one's Avatar
THANK YOU!........... i knew i was not crazy
Old Sep 12, 2005 | 06:34 AM
Close. It's a percentage of the cross-section width, not the tread width. It is possible to have the same cross-section and surprizingly wider or narrower tread, so the series is a percentage of the cross-sectional width on a standard rim size (if you look up the specs for any tire, they will have a narrow, recommended, and wide rim specified for each size.)
If the rims are narrower or wider than the one used for the official measurements, they may be taller or shorter respectively. For the tire to perform best, you should use the recommended rim width. This is why I went with the GN+ for 245s despite being quite a bit heavier than FN01RCs. It all has to work together...
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
prescottn
Sep 13, 2015 09:04 PM
KSwag
Sep 1, 2015 08:04 PM
Subaru86
Jul 31, 2015 04:33 AM
Davyo
Jul 29, 2015 05:53 AM
