xB radio Specs
Old Mar 26, 2004 | 08:08 PM
chimjuga's Avatar
Default xB radio Specs
I already have a powered bazooka from my old car and i was wanting to install it. I was curious if anyone has a back shot of the factory radio or knew if it had rca preouts so that i can no what i'm up against before i start. Any help or input would be appreciated......thanx :?:
Old Mar 26, 2004 | 08:38 PM
OKIHost's Avatar
It does not have pre-outs.. I was hoping the same thing.. There is something called an 'inverter' I think someone here told me about and you can hookup an amp, tube etc when you get one of those..
Old Mar 27, 2004 | 07:20 PM
one80ikyu's Avatar
Go to a local stereo shop and tell them what you want to do, and they will give you an inverter for it. It should run around 10 dollars or so, and that will allow you to hook up amps, etc.
Old Mar 29, 2004 | 01:25 AM
urban_assault_XB's Avatar
I have one on my car because I don't have all the money for my new set up which will be a pop out tv with the cd player under it. Any way go to a car stero store and by a line outoput converter it is a black box with 2 female out puts and 6 wires coming out the other side the PAC brand is great its what I sale in my store. This is the easiest way to hook it up either look at the radio wiring post on scionlife.com or pop out the front dash speaker grills and lok at the wire colors from each speaker then hook up the white set from the converter to the right side front speaker wires right behind the deck and do the same to the other set of grey wires using the wires color from the front left speaker then just pulg in your rca to the converter you dont have to use the last 2 wires which are grounds just tape up the ends and thats it.
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
pjl52
Aug 13, 2015 02:38 PM
TheRealShark
Scion tC 2G ICE & Interior
Aug 5, 2015 05:08 PM
semlin
Jul 29, 2015 02:07 AM
Azsundevil
Jul 25, 2015 11:10 PM
