View Full Version : Aftermarket Foglights?
WhiteToaster
10-16-2003, 10:12 AM
Do they make aftermarket foglights for the XB??Anyone unhappy with their factory?? I only wish it was a little lower..
eric_m
10-16-2003, 03:12 PM
here is a picture of my car at the last show. i got some cheap rectangle foglights, mainly for looks. they shine yellow and a bunch of other colors and make a cool pattern on the ground. i flush mounted them in the corners of the honeycomb grill, and then put a randode racing aluminum grill over the lights so it would look clean.
here is a closeup of the foglight.
http://eric.myimprezawrx.com/photos/albums/userpics/fog.jpg
ScionJohn
10-16-2003, 04:52 PM
I put some old school PIIA light on mine. If you are going to put any aftermarket foglight on the bottom of the grill, be sure to clear the towing bolt next to it.
http://www.mattguillory.com/gallery/album06/John_01
eric_m
10-16-2003, 04:55 PM
those look good, john.
scionlife
10-16-2003, 05:38 PM
moved to: Bumps, Beats, Seats & Volts
ScionJohn
10-16-2003, 06:07 PM
Thanks Erik! These Piaa fog lamps have been sitting in my garage since '95. I was going to put them on my Civic then. I think I got a good home for them now! Nice grill setup on you XB! By the way Gabe (Stylis) say's "What's up!". Late...
squirrel
10-16-2003, 08:26 PM
I ordered some PIAA driving lights for my xB. They're the 6 inch rounds IIRC. I made a new bracket out of aluminum, and am adding the xenon(?) bulbs. Once I get the HID installed, I'll be able to see just about everything in front of me. Central Valley fog won't be slowing me that much this winter!
squirrel
xB_ey
10-16-2003, 09:41 PM
squirrel,
can't wait to see that, and where you mount them. i was thinking about that myself...part of the "winterization" of my bB.
George
10-16-2003, 09:44 PM
Y'know, you could put some decent sized fog or driving lights into the top "grille" pretty easily. Just cut the grille to clear, make brackets to go back to the structure behind and you're in business!
It was pointed out to me at the Canyon Cruise that the top "grille" isn't a grille at all, but a solid panel shaped to make it look like a grille. It's a nice big opening to put stuff if you need it!
George
drez14
10-17-2003, 03:21 AM
Hi everyone! Ive been surfing the site for about a month, and got my xb about 2 weeks ago. Great Site!!
I just wanted to put the word out that i will be selling aftermarket fog light kits for the XA and XB. It will include the housing, relay, and switch. The kit looks pretty much like the factory kit. I dont have pricing info but i will keep you all posted.
thanks
ScionizeD
10-17-2003, 03:58 AM
thanks
Got any pics? Will it be using the factory harness?
batute
10-17-2003, 04:09 AM
from what I read at the overboost post, xB are pre-wired and all you need are the foglights, relay and the switch...I have an xA and I couldn't find the wires/switch/plugs , guess xAs are not pre-wired ?
drez14
10-17-2003, 05:15 AM
The XB is prewired. What i forgot to mention is that the XA kit will actually come with wires with oem style connectors for easy install. No Pics yet. It looks identical to the factory. The interior switch may be a little different, but will definatly fit in the foctory hole.
yanges
10-20-2003, 04:50 PM
i heard someone put PIAA yellow fog bulbs in their Scion fog lamps...
anyone know where i can find some of those? i have been looking but can not seem to find any....
thanks
bBted
10-20-2003, 05:02 PM
thanks
i tried them before, but just just look like the stock one, but a little bit yellowish...
but u can still see yellow from certain angle
quadraphonic
10-21-2003, 01:03 AM
You guys might find that the Hella Optilux 1300s fit.. they're 3.5" round fogs. With a nice white bulb in there they should look pretty good.
DoWopBx
05-08-2005, 02:41 AM
Has anyone found a generic or cheap replacement for the stock foglight relay (xB)?
Are they available and if so, how much are they from Toyota?
quadraphonic
05-08-2005, 05:21 AM
Conicelli sells one.. here's a listing for the '03 echo, probably the same part though.
http://www.trademotion.com/partlocator/index.cfm?action=getLocatorKeySearch&siteid=840&chapter=APM818&catalogid=1&year=2003&make=34&model=Echo
Look through the list for the relay.. sells for $40.65
