Secret Weapon Help(Big pics inside)
Old Sep 15, 2005 | 02:11 AM
Ericc's Avatar
Default Secret Weapon Help(Big pics inside)
Hi, I bought the Secret Weapon intake.
And I read the FAQ install that someone made.
My question is , First off, my pipe looks different.
And my couplers looks differnt is this normal?
I cant even get the coupler onto the pipe ><
Anyone have any tips?
here are some pics
Here Im showing what part I can not connect.
Old Sep 15, 2005 | 02:27 AM
Kenshin's Avatar
That coupler (the reducer), the big sides goes onto the pipe, the small side to the throttle body.
Old Sep 15, 2005 | 02:32 AM
Ericc's Avatar
Thats not the side Im having trouble with, its the filter side.
Both the Couplers look the same, is that right?
Old Sep 15, 2005 | 02:34 AM
BADS33D's Avatar
1UP Crew
well, u gotta squeeze it in real tite. it isnt just gonna plug in by itself...its a real tight fit, so just keep trying...u got the right stuff tho.
Old Sep 15, 2005 | 02:44 AM
Ericc's Avatar
k, just making sure its supposed to be super tight, I have been trying for 2 hours, and my hands are getting tired ><
Old Sep 15, 2005 | 02:47 AM
Jarrod123's Avatar
good luck guy..
Old Sep 15, 2005 | 02:52 AM
Ericc's Avatar
ok, I finally got it. Sliced my finger on the pipe while doing it =O.
Damn, I suck, haha. Hope it isnt as hard to get it on the throttle body. ALl the other connections seem super easy.
Old Sep 15, 2005 | 11:20 PM
Tobias455's Avatar
Just make sure you put the flexible reducer onto the throttle body first , and take your time to make sure there is a good seal between the TB and the reducer, and again between the reducer and the intake pipe. I just installed mine two days ago and learned the hard way.
Good luck...
By the way don't forget to disconnect your negative terminal from the battery to reset the ECU. When your done hook it back up and let her idle for five or so minutes before reving it up. That should allow the ECU time to get to know the intake.
Old Sep 16, 2005 | 03:19 AM
Weapon-R's Avatar
if you cant get the reducer on the pipe, just put the reducer in the microwave for 30 seconds. and it should be more flexible.
Old Sep 16, 2005 | 03:27 AM
tCb00b's Avatar
I always say a little lube goes a long way.
Old Sep 16, 2005 | 03:32 AM
Weapon-R's Avatar
Ones who use would only know.. ahahah
Old Sep 16, 2005 | 04:03 AM
tCb00b's Avatar
Man with a wide body tc speaks the truth. LMAO
stayintrucha
Mar 17, 2015 08:45 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
cavalierkid888
Jan 8, 2015 04:42 AM
Joeynenj
Nov 25, 2014 05:29 AM
scioninla
14
Oct 18, 2003 03:46 AM
