Who installed the Hotchkis front Sway bars themselves?
Old Sep 15, 2005 | 02:30 PM
csh8428's Avatar
Default Who installed the Hotchkis front Sway bars themselves?
Who installed the front sway bars themselves?
How hard was it?
What kind of experience do yu have?
Did you use a lift or blocks?
Thanx,
Craig
Old Sep 15, 2005 | 05:02 PM
Complication's Avatar
I sure didn't, I could of installed the rear no problem, but the front is a |3itch... don't try if you've never donanything like this before. it will take you days... and yeah the best way si to get it up on a lift.
Old Sep 15, 2005 | 08:14 PM
DTRUONG_112's Avatar
I have an engine lift at home but not sure how hard it'll be so I'm taking it to a shop for it to get done.
Old Sep 16, 2005 | 01:31 AM
InLikeFlint's Avatar
I did it, used jack and jack stands, start to finish on the front bar took me about 4-5 hours. I only attempted it, because my dad was helping me, and he's been wrenching on cars for decades.
Old Sep 16, 2005 | 04:35 AM
Howd you do it? Steps? How-to?
Old Sep 16, 2005 | 04:54 AM
yeah 4-5 hours even with someone who's been working on cars for years... get it done right and pay the install cash, you won;t regret it.
Old Sep 16, 2005 | 08:25 AM
lo_bux_racer's Avatar
Me.
How hard was it?
On a scale of 1 to 10 where 1 is an oil change, 4 is a clutch/flywheel change (for a tC), and 10 is a full port and polish, I'd call it a 3.
Lots over the last 25 years or so.
Four jackstands. You could do it with two if you wanted. I would never work under a car on blocks. PM me if you want the complete low down.
Old Sep 18, 2005 | 11:43 PM
yamaha16bw's Avatar
Yeah I just used 2 jack stands and did the front first....it was a pain but not too bad. A buddy of mine helped out but other then that i have had very little wrenching on cars. Ive been working on motorcycles for years though.
As for the rear took about 20 minutes.
Only tip i could give would be to make sure you center the steering rack when putting it back on the front cradle. If you dont your steering wheel will not be centered when your done.
Old Sep 19, 2005 | 02:08 AM
Marshall's Avatar
I did the install myself and I had someone use their air wrench to loosesn the four cradle bolts.
Two jack stands, with rear wheels stops worked just fine for me. You will learn so much from doing this install yourself... But I don't recommend it unless you've wrenched something before.
While your steernig wheel is perfectly straight, you might want to try jamming a block object between the front seat and steering wheel so the steering wheel stays unmoved as possible...
Also make sure to use another jack in the very center of the steering cradle to raise it while your tightening bolts. That way it stays even and you dont ahve to Force the bolts in where there of course get stripped if you do.
You can do it yourself... if you can't then you can take into a shop. Might want to get quotes beforehand. Good luck.
Old Sep 19, 2005 | 04:25 AM
I didn't pay any attention to the steering at all. It didn't move in the slightest.
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
