STS Turbo Systems
Old Sep 15, 2005 | 08:46 PM
rhythmnsmoke's Avatar
Music City Scions
Default STS Turbo Systems
When I was getting my exhaust system installed, I took a look at this Camero SS. I wanted to see what was done to it, and how the piping underneath looked, because I was getting piping done at the very same place. So, I got down and discovered this. This is the shop owner's car.
http://media.putfile.com/STS-Turbo
Old Sep 15, 2005 | 09:02 PM
chubster41's Avatar
damm I had alink to this type of turbo but I cant find it......its very unique
Old Sep 15, 2005 | 09:04 PM
slammed's Avatar
that is very clean. I have seen setups like this before, but not on a camaro. I saw the same but reversed on a vw bug.
Old Sep 15, 2005 | 09:05 PM
jmiller20874's Avatar
Interesting place for a turbo. How's that lag?
Old Sep 15, 2005 | 09:22 PM
Music City Scions
My first thought was, "what if it rains, and the street floods". I thought that would be the end of your boost.
Old Sep 15, 2005 | 09:26 PM
Munch's Avatar
The perfect sleeper. Open the hood and nothing there. Easy money
Old Sep 15, 2005 | 09:40 PM
chubster41's Avatar
one thing for sure is alot more piping
Old Sep 15, 2005 | 09:53 PM
reagulator's Avatar
that turbo isnt protected or anything. A rock could destroy that thing
Old Sep 15, 2005 | 10:41 PM
TurboCustomz's Avatar
These STS systems have been around for a while now. There has been quite a bit of contraversy about them as well. I looked into them for a while when I was entertaining the idea of boosting my Camaro. They are actually engineered quite well. The trick is matching the correct size turbo, especially the exhaust housing, to the engine in the car. Mounting the turbo in the back of the car gets rid of all the extra heat under the hood. The sleeper thing kinda goes out the window because they have quite a bit of turbine noise. There is very little room for a real exhaust system.
Matching the turbo to the car is key here. When done correctly, you can achieve a decent HP increase and lag is not really an issue. Using a smaller exhaust housing, can re-create velocity that is lost with the substantially cooler exhaust temps. Plus, without the intercooler, pressure drop is non-exhistant. The ambiant air rushing under the car cools the pipes and causes an intercooling effect. Thickness, and make of the pipe have a lot to do with this also. Aluminum dissapeats heat much more rapidly then steel, and ideally would be used on these kits.
I've talked to some people at greddy about the induction of water on the hot turbo creating problems. I thought for sure that water splashing up on the exhaust housing of a hot turbo would cause it to crack. They have informed me that you would have to nearly submerge the entire thing in water to cause it to cool down fast enough to cause any serious issues. I guess its much more likely with the turbo mounted at the back of the car, but still not likely.
I definatly wouldn't recommend one of these kits for a smaller displacement engine, or for someone that wanted to really squeeze every last horsepower possible out of their engine. The front mounted kits are just much more effcient at making power at higher levels. However, they seem ideally priced for someone that wants a reliable kick in the pants or someone that tows a lot.
Charles
Old Sep 16, 2005 | 03:39 AM
R_I_P_CtCF's Avatar
I actually heard about these turbos awhile back and decide to email them to see if they might ever make a kit for the tC this is what I got in response.
Thank you for your interest in a turbo system from STS. Unfortunately we don't have a bolt-on kit for your vehicle at this time.
We get literally hundreds of requests for new vehicles each week and we will be announcing new kits soon.
I'll put you in our database and we'll contact you when we have a kit for your vehicle.
We do sell a universal turbo system through our authorized dealers that can be modified to fit many vehicles. It will cost more than one of our normal systems due to the custom fabrication and tuning that would need to take place. If you are interested in pursuing this option, please get back to me and I'll set you up with a dealer in your area.
Thanks,
Brady
sidenote I heard they now sell kit s for civics and acuras
Old Sep 16, 2005 | 04:19 AM
Whocares05050's Avatar
Its nothing new, i know someone in my area with one under his trans am. alot more piping, but he still runs in the 12's with nothing but the turbo and its an automatic
Old Sep 16, 2005 | 09:52 AM
lo_bux_racer's Avatar
Sure would suck to have an oil line fail on one of those. It's a long way from the engine to the turbo.
Old Sep 17, 2005 | 06:49 AM
TimmyT's Avatar
Scion Society
Do you guys know WHY the turbo is back there? Cause there is no room in the engine bay.. DUH.
My uncle has a Camaro SS. You have to Drop the engine out from underneath the car to remove it. There is no room in the engine bay to mount the turbo, manifold, and piping without some cutting and hood alterations.
Old Sep 17, 2005 | 07:40 AM
krazylowgsx's Avatar
Some turbos are "dry" which doesn't require an oil line... only coolant. I would imagine that the STS would use oil tho. and yes... that is a long way back, but if installed properly, i bet there won't be any issues.
Looks like a nice size turbo too! And i love the Tial WG. I'm a tial nut
Old Sep 17, 2005 | 11:32 AM
I think you might be backwards my friend. I've seen plenty of turbo's that didnt have to had coolant lines, but never one that ran without oil.
I think the STS kits use an external push style pump to make sure there's enough "umph" to get all that oil back to the engine. I also believe that the returning oil just dumps back into the valve cover most cases.
Old Sep 17, 2005 | 02:45 PM
In the valve cover? Hmmm. Ever see the oil coming off a turbo? It looks like chocolate mousse. That's why the return lines are so much bigger than the feed lines. That oil pulls a lot of heat out of the unit.
Oh, well, it works, people are running them. It wouldn't make sense for us, we have lots of room in the engine bay for something like a turbo.
CrowJenkins
May 4, 2015 04:52 AM
mav261
Mar 24, 2015 01:19 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
spawnconnery
Dec 18, 2014 08:38 PM
Professor_Scion
Jan 7, 2004 08:10 PM
