Sniffs
09-16-2005, 09:55 PM
I recently purchased a tC and about a month or so prior my brother got a G35.. Well he is thinking about buying new rims/tires and said that if the G35 rims/tires fit on my car, that I could have them for free.. Does anyone know if they'll fit??? I believe the lugnut pattern may be roughly the same, but tire thickness, etc..
Thanks.
ack154
09-16-2005, 09:56 PM
Moved to T&B... :lalala:
The bolt pattern is 5x100. I couldn't tell you anymore... but the Tread and Butter people can help you out.
maximus96
09-17-2005, 12:25 AM
i have the 17" G35 sedan rims on my maxima, tire is thicker than stock tc tires. i never tried swapping them onto the tc so can't tell you if they fit or not.
HKSpeed
09-17-2005, 01:36 AM
G35 is 5x114.3.
sorry.
you could get them drilled for 5x100. Most places charge $75-95 per wheel.
Eppopipe
09-17-2005, 03:48 AM
there are spacers to make em fit on ebay for 100$
Kilo6_one
09-17-2005, 03:54 AM
what kind are they? i may be intrested if they are the 05 19" rims.
HKSpeed
09-17-2005, 06:29 AM
you gotta think about offset. most of those spacers are 1 inch, which is 24 mm. Unless the wheel is et50, such a spacer will kick those wheels out too much (and rub hard if youre lowered). If youre using et50-55 wheels made for a S2000 or NSX, then it might work.
Another thing to consider is how the back of the wheel hub is designed. Make sure it has grooves between the lug wholes to fit the stock wheel studs (hard to explain without a photo).
tinybigrig
09-19-2005, 04:03 PM
stock g35 setup for 18in wheels is 18x7.5 up front 18x8 in the rear, this is for 18s, offset is 35, if you ran an adaptor spacer it would push it out waaaaay to far for any sort of driving
brent
