ANother Spring Rate Question....Hope Sombebody Knows
Old Sep 17, 2005 | 12:12 AM
Sciond's Avatar
Default ANother Spring Rate Question....Hope Sombebody Knows
Which springs excluding coil overs have progressive spring rates for the XB???? I only see one on the spring rate charts.....is that accurate?
Thanks for your help in advance....
Old Sep 17, 2005 | 01:24 AM
HaVoK's Avatar
The Eibachs are progressive and I believe the TRDs are also progressive (as they are made by Eibach to TRD specs). And there are the KG/mm springs that are also progressive.
Old Sep 17, 2005 | 01:51 AM
jomo's Avatar
Default Re: ANother Spring Rate Question....Hope Sombebody Knows
By the way, progressive (or dual rate) springs are not necessarily an indication of quality. Progressive springs are more a necessity when lowering a stock suspenion (to keep the springs from falling out). The more you lower or the higher the resting spring rate, the more progressive springs are required. If a lowering spring is linear, it is probably and indication that it does not lower that much and/or the ride is pretty soft/comfortable. As long as you use a reputable spring manufacturer, you should be fine with either linear or progressive.
There is a bit of marketing in the word "progressive".
Old Sep 17, 2005 | 01:55 AM
Sciond's Avatar
I am aware.. I want a compliant suspension....
Old Sep 17, 2005 | 03:18 AM
jomo's Avatar
Then you should look for more linear, less progressive......
Old Sep 18, 2005 | 08:11 PM
Sciond's Avatar
ok... excpet when I drive it hard..I shoulda stated that...oops
Old Sep 22, 2005 | 07:43 PM
Sciond's Avatar
more opinions??
Old Sep 28, 2005 | 03:57 PM
TheComputerMan's Avatar
more opinions??
dude, your 99 years old! your gonna die soon anyways, so who cares about springs. ;)
Old Sep 29, 2005 | 01:56 AM
sandccie's Avatar
I had a set of Eibach Pro-Kit (which is advertised as progressive springs) on my xA for 6 months. Although I loved the handling and stiffy feel, the ride was harsh to me as a daily commuter in NY/NJ area.
my2cents.
Sam
Old Sep 29, 2005 | 02:36 AM
Sciond's Avatar
more opinions??
gonna go out with a bang...
Old Sep 29, 2005 | 02:37 AM
Sciond's Avatar
my2cents.
Sam
man I do not miss those roads..I am from that area
Old Sep 30, 2005 | 02:30 AM
sandccie's Avatar
I hear ya. Wish I can move out of NY and start a new life :-)
Anyway, TRD/Eibach spring + TRD struts/shocks will definitely give u a compliant suspension...
I still have the Eibach Pro-Kit spring set sleeping in my basement. Let me know if u r interested.
Sam
Old Nov 17, 2005 | 03:32 AM
Chimmy3's Avatar
btw the chart is compiled information from the manufacturer of listed springs. Unless they posted incorrect info (or when I called them), it should be accurate.
mc1114
Aug 12, 2015 02:07 AM
kanundrum
Regional - Mid South
Aug 4, 2015 04:23 AM
Mjdavis1994
Jul 18, 2015 04:29 AM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
