The key to getting better MPG out of your xB
Old Sep 17, 2005 | 07:14 AM
dgboggs's Avatar
Default The key to getting better MPG out of your xB
I was getting 30-31 MPG. '05 5 sp 17" wheels. I drive very gentle, and I never went over 3000 rpm. 1200 miles on the odo. 90% city driving
This last tank I decided to try only taking the RPM's to around 2700. I was unsure of when the vvt kicked in, but I knew that I was feeling more power at around 2800-2900, so I figured that is the first threshold. I instantly saw results when I filled up today- 33.3 MPG!!
You will not get anywhere quickly, but man, I LOVE that number!!
Old Sep 17, 2005 | 12:32 PM
Prototype_xB's Avatar
something i'll have to try!!
I have a question though.....How are you finding out your MPG??
Old Sep 17, 2005 | 12:40 PM
LunchLady's Avatar
I bought mine less than a week ago and have only used half a tank and have gone 190 miles! (not an hour)
Old Sep 17, 2005 | 01:15 PM
FrankenScion's Avatar
When you fill up reset your tripometer. Next time you fill up divide how many miles you went by how many gallons you just put in.
Old Sep 17, 2005 | 01:51 PM
TheComputerMan's Avatar
So wait one second. YOur telling me that if I put 10 gallons of fuel in and i only have 220 miles on my trip, then im getting 22MPG?
Old Sep 17, 2005 | 02:06 PM
Sciond's Avatar
the most accurate way I know to do this is to fill until it clicks off and then when you refill do the same then divide miles by gallons..my las tank 34mpg driving it hard....
Old Sep 17, 2005 | 02:45 PM
Simplyscion's Avatar
Team No Limitz
before I even put the turbo on my car I was only getting like 230 miles to a fill up...I wasnt really driving too much highway though. I was figuring about 23 mpg w/ I/H/E and pulley. Now I get like 180 miles to a tank if I hit the highway for a lil bit. I need to put a smaller fuel pump in there, the 255LPH is too much right now.
Old Sep 17, 2005 | 02:46 PM
Sciond's Avatar
^^^^^ouch
Old Sep 17, 2005 | 04:05 PM
heavypetting's Avatar
Default it depends...
Computing gas mileage can be tricky. You also need to know how much is left in your tank.
When my low gas light comes on, I figure I still have about 1.5 gallons in the tank. So if you are assuming your almost empty when you still have 1.5 gallons left your MPG will divide out to be much lower.
Yes, my rooster has his own website,
www.mrjoy.net
Old Sep 17, 2005 | 04:40 PM
Team No Limitz
u are weird w/ your rooster web site
Old Sep 17, 2005 | 04:49 PM
OneBadBox's Avatar
To add to the accuracy, this should be done over several fill-ups.
Old Sep 17, 2005 | 04:53 PM
chucksu's Avatar
about 600 miles on the odo. 17x7 Wheels with a 215/40R17 Falken tire. I have a SRI+Exhaust. My worst tank was 32mpg (all around town w/ac on) My best was 39.24xxmpg (still around town but less stop & go no ac) I have a 5spd also. The thing to try though, is shifting before 2500rpm, My normal day to day shift is around 2200rpm.
Old Sep 17, 2005 | 05:18 PM
dgboggs's Avatar
That's what I'm going to try this time.
In reference to figuring: I have a small notepad, and I keep track of each tank. I fill to the first click. If you're getting 190 at the 1/2 tank mark, then you're looking at around 32 mpg. For example: I was a full needle mark above 1/4, and I had something to the effect of 260 miles. I divided that into the gallons (7.8, if I recall correctly) = 33.33 MPG.
Old Sep 17, 2005 | 06:42 PM
LunchLady's Avatar
Yeah, I was at 190 at half a tank.... filled today 6.6 gals to fill and 219 on the odo at the time about 33mi/gal? first tank of gas ever!
Old Sep 19, 2005 | 02:52 AM
custom2k1's Avatar
wow is there something wrong with my xb? I just put in 9.4 gallons and got 239 miles. So thats about 25 mpg. I drive 100 miles a day on the highway and only have an intake for performance but have 18x7 wheels with 215/35/18 tires.
Any suggestions?
Old Sep 19, 2005 | 03:06 AM
hotbox05's Avatar
If you shift below 3k you get awesome mileage.
You will also be the slowest car on the road. At least where I live .
Old Sep 19, 2005 | 08:30 AM
dgboggs's Avatar
Any suggestions?
Your wheels are too heavy, and you're driving on the highway, probably at high rpm's. The only way to get GOOD highway mileage is to be able to drive non-stop at a steady speed. My box gets worse mileage on the 'highway', because around here the highways have stoplights, and anything over 58 mph and the rmps are around 3k. Your intake is also forcing more gas/air.
Old Sep 19, 2005 | 09:00 AM
B2FiNiTY's Avatar
I highly doubt this. How are you calculating your mpg? Doesn't sound right at all.
Old Sep 19, 2005 | 12:21 PM
Sciond's Avatar
I tend to agree....
Old Sep 19, 2005 | 01:24 PM
4est's Avatar
OK, If I'm reading the above posts (and other threads) correctly, a lot of ppl are making this complicated when it is not. ALWAYS ignore the gas gauge for mileage calculations.
1. Fill tank (stop at one or 2 clicks)
2. Reset trip meter
3. Drive until time to refill
4. Fill tank in the same manner as before and check the gallons of gas just purchased
5. Divide the number of miles driven by the number of gallons just purchased
Viola
As stated above, if you do this over several tanks of gas, you will get a more accurate average.
** Note: Your Mileage May Vary **
