Joe_Dezod
09-17-2005, 06:33 PM
This DIY will definately take longer to write up than the actual DIY itself. With this layout, it takes less time to install a FULL-featured emanage than it does to change out a set of wheels.
OFFICIAL DEZOD Greddy Emanage PnP Installation:
Tools/Materials Needed:
1. Supplied hardware within Emanage Box
2. Dezod PnP Emanage harness ($280)
3. Greddy Emanage
4. Double-sided high strenght tape (for mounting Emanage)
5. 10MM socket or open-ended wrench
6. Support tool (STRONGLY reccommended)
Step 1: Look at starting time.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_177_full.jpg
Step 2: Remove ground cable from negative (-) terminal of battery.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_178_full.jpg
Step 3: Stare and drool at your miracle in a wire.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_179_full.jpg
Step 4: Set rotary settings. These settings are to stay private until our kits are being sold. Anyone who buys our Deozd PnP harness will be provided with these settings, along with Support tool parameter settings for proper installation prior to turbo install. To set the rotary settings, use the supplied allen wrench key in your Emanage Blue box. There are four screws (one on each corner) that you need to remove. Your are taking the side off that is on the same side of the USB plug, not the harness side.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_180_full.jpg
Step 5: Remove glove box from dash. To do this, you need to remove a small plastic balancer on the bottom right of the glove box (FIG1). After doing so, push 2 tabs in firmly (one on each side) and pull down on the glove box at the same time. (FIG2)
*FIG1
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_187_full.jpg
*FIG2
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_189_full.jpg
Step 6: Factory harnesses removal. Look at all of your ECU harnesses! Unplug all 5 of them. (Don't mind my extra wires there, it's for the Apexi RSM and custom system I made).
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_182_full.jpg
Step 7: Installing Dezod PnP Emanage harness. Plug the original ECU harnesses into the solid white block, which replicates your ECU block.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_183_full.jpg
Step 8: Installing Dezod PnP harness pt 2. Plug the new harnesses back into your stock ECU.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_184_full.jpg
Step 9: Look at the 2 Greddy harnesses coming out of the mess of wires and realize how much time you just saved.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_186_full.jpg
Step 10: Plug 2 grey harnesses into your Emanage Blue.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_188_full.jpg
Step 11: Reconnect battery ground onto negative terminal.
Step 12: Look back at time. It only took 13 minutes, and that's with taking pictures throughout the process.
http://memimage.cardomain.net/member_images/8/web/704000-704999/704420_190_full.jpg
After doing all of this you will need to install the firmware and support tool updates before running the emanage. We encourage you to buy the support tool as well because this is the only way to properly setup and calibrate your emanage. Please post up or email me with any questions or concerns regarding this DIY or the parts themselves.
**Update: Pre-order has been extended to the end of the month!!!
Use this thread to buy or call 954-757-7992
http://www.scionlife.com/forums/viewtopic.php?t=77452&postdays=0&postorder=asc&start=0
3. Greddy Emanage
*FIG1
*FIG2
