Making the 1NZ-FE more durable?
Old Sep 18, 2005 | 03:23 AM
thatsfetch's Avatar
Default Making the 1NZ-FE more durable?
How can I make the 1NZ-FE more durable for hard driving?
Old Sep 18, 2005 | 03:25 AM
crazy_kat_matt's Avatar
lots of money =p. just rebuild everything, forge rods and pistons, cams, cryotreated internals, stroker kit. there are many possibilities
Old Sep 18, 2005 | 10:53 PM
Newtmaker's Avatar
It would mostly depend on what your definition of hard driving is. If you are referring to driving hard with moderatly high shift point rpm's, hard braking, and high speeds over long periods, then just using good maintenance procedures will probably suffice. However, if you mean adding performance enhancement equipment such as turbo or supercharging, then the beefing up of internal components will most likely be necessary for longevity.
These little engines are designed to work hard so they can take hard use. Just don't abuse!! I would categorize abuse as overreving a lot, especially in the lower gears. Hard power shifts, driving hard when the engine is cold or too hot would also be bad.
My 2nd Toyota was a 72 Corolla with a 1.6 L engine. It too was a peppy responsive engine and I pretty much kept on top of it all the time. ( I was younger then ;-) ) The car lasted me well over 100k miles and I never broke anything. The clutch was still fine when I sold it. The buyer put several 10's of thousand on it when the oil pump finally let go.
Walt
Old Sep 18, 2005 | 11:40 PM
BeQuietAndDrive's Avatar
The 1NZFE is raced in quite a few series around the world (Echo Cup Canada, Yaris Cup Germany, Vitz Cup Japan), and those engines are internally stock. So, I'm willing to say the 1NZ is quite a durable little motor.
Old Sep 18, 2005 | 11:54 PM
hotbox05's Avatar
it's very very reliable as a paper weight.
Old Sep 19, 2005 | 09:22 PM
David_Seale's Avatar
NonStopTuning
Jan 20, 2015 05:20 AM
eric_m
79
Mar 17, 2013 12:21 AM
