Eurathane mounts, make them now or wait:)
Old Sep 20, 2005 | 09:16 PM
raamaudio's Avatar
Default Eurathane mounts, make them now or wait:)
If you can let your car sit for a couple of days you can make your own filled mounts.
I use Devcon Flexane 80, a two part eurathane casting compound.
Just pull the front and rear mounts out, tape up one side really well, set them on a solid surface and well balanced, supported. Mix the eurathane and pour until filled to the edge of the mount. Let it sit and when done peal off the tape and intall them.
A 1 lb kit is plenty to do two cars front and rear mounts, costs around $30 per kit, a bit tough to find, I found a local dealer on the Devcon website then called them to order it, had it one day later
http://www.devcon.com/devconfamilypr...m?familyid=151
Rick
Old Sep 21, 2005 | 01:20 AM
VoLktc's Avatar
so did you notice a diffrence?
Old Sep 21, 2005 | 01:30 AM
xnevergiveinx's Avatar
post up a DIY please!!!!
Old Sep 21, 2005 | 04:22 AM
raamaudio's Avatar
I have not done the tC just yet, we are finishing up our shop setup then will get busy dropping the tranny to install the LSD, 10lb flywheel, PP, 6 puc sprung clutch, fill the crossmember with structural expanding foam, fill the mounts, install the front sway bar and finish up by installing the Wilwood BBK they custom made for us
We will take alot of pics and when have time post the whole scenario.
I already know they will make a huge difference, done them on other cars before
Rick
XirtaXa
24
Jan 14, 2025 03:49 PM
MinusPrevious
15
Dec 12, 2020 06:47 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
ToyTuners
Nov 4, 2003 07:17 AM
