grounding wires + voltage stabalizer???
Old Sep 20, 2005 | 11:03 PM
miamibusta69's Avatar
Default grounding wires + voltage stabalizer???
Ok i just bought Grounding wires.. And my question is can i also install a voltage stabalizer? WOuld there be a positive to this or a negative??
Thanks
Old Sep 20, 2005 | 11:22 PM
BrEaK_AwaY's Avatar
positive if you have a sound system pushing some serius power.
negative because it wont do much of anything performance wise
Old Sep 20, 2005 | 11:33 PM
I only have a 550 true watt alpine. But i just changed my stock radio to a touchscreen dvd player. and now my speakers break up when i try 2 play them loud.. wonder if ground wires will help that.. Or i just might have to buy new speakers or an extra amp..
Old Sep 20, 2005 | 11:43 PM
BrEaK_AwaY's Avatar
you probably need to replace your speakers. and if you do that, you might as well get a 4 way amp to power them, and replace all the speaker wire with a better wire.
Old Sep 20, 2005 | 11:53 PM
yeah the stock wires suck lol.. how much watt would you suggest for the 4 way? this will make my speakers louder as well right?
Old Sep 20, 2005 | 11:59 PM
mr_lore's Avatar
When I first installed my groundfusion 8 point grouding kit I had the stock radio setup and it got noticably louder. A grounding kit and a voltage stabalizer can only make the voltage across the entire car better overall, just how much better than just one or the other is the question thats difficult to answer.
Old Sep 21, 2005 | 12:02 AM
BrEaK_AwaY's Avatar
i couldnt DIS agree more.
i also have the ground fusion grounding kit, but i got it for when I install my 2 700W mono amps. i think what you heard was in your head.
Old Sep 21, 2005 | 12:21 AM
well ill let u know what i think when i get mine they should be coming very soon
I got mine from www.k2motor.com they are cheap!
Old Sep 21, 2005 | 02:56 AM
mr_lore's Avatar
the only reason i noticed it was b/c i had a fav volume setting for when I had my windows up and that was 34 and I was listening to Jet - cold hard _____ alot in the summer. after the install 34 was so loud it hurt my ears a bit so the new setting was 32, two increments was all the difference but it was fefinetly there.
Old Sep 24, 2005 | 12:00 AM
Ok i just got this thing .. ANd i have no idea how to install it so i went out side and just hooked it up to all the places i could find. i tryed to close my hood it wouldent close the wires were in the way i put it in the wrong places.... so i tryed to at least start my car when it tryed to turn over it just shut off and wouldent start again.. so i had to take every thing apart !! can some one please show me how to install this type of ground wire kit from the picture above.Plz !~~~~~
Old Sep 24, 2005 | 09:16 AM
turbo2liter's Avatar
You installed a ground wire kit, and then your car wouldn't start?
This may top the guy that tapped his valve cover for nitrous.
Old Sep 24, 2005 | 04:34 PM
I did not know how to install it. i mounted 3 to the head lol couldent find any more spots that would fit... still looking for help...
Old Sep 24, 2005 | 09:21 PM
mr_lore's Avatar
heh, you probably tried to ground something that was hot(positive) and got a nice feedback from it. If you unhooked everything and your car still doesnt start look for a poped fuse, if you cant find one, disconnect the positive battery terminal for 10mins and then try again.
Old Sep 25, 2005 | 04:32 AM
no i just disconnected the ground wites and put it back 2 stock
Nerdcore314
May 1, 2015 11:54 PM
randode
44
Jun 29, 2004 04:19 PM
pmpnxb
11
Jan 27, 2004 04:36 AM
bryanrx7
Jan 1, 2004 09:53 PM
deathcabforme
Oct 16, 2003 04:02 AM
