Alternators
Old Mar 29, 2004 | 11:22 PM
scibrew's Avatar
Default Alternators
Is there any way to beef up the stock alternator? Or are there any good aftermarket that are being used?
-scibrew-
Old Mar 30, 2004 | 02:31 AM
ScionPimp's Avatar
Default Re: Alternators
Contact AAMP of America (Stinger) and have one made to the specs you want... if you are going to do it, do it right.
[/url]www.stinger-aamp.com ask for Jake.
Old Mar 30, 2004 | 05:29 AM
rolex87's Avatar
Default Warranty
What would you do to the warranty? I mean, replacing something that's actually on the serpentine belt. I definitely don't want to void that!!! As a semi-compromise, I'm running a Stinger SP1000 and Phoenix Gold Titanium 15 Farad capacitor. My stereo shop said that would redice strain on my alternator + battery. I don't use the A/C much. Just my stereo. i think the Stinger alts. have a 1(?) year warranty if I'm not mistaken. Or I guess Toyota can say that my stereo caused my alternator to fail and not fix it. Any advice?
Mike R.
rolex87
Old May 9, 2004 | 04:00 AM
NisAznMonk's Avatar
use www.google.com and search for Iraggi Alternators. He builds custom alternators for car audio competitors around the country. I bought a 220 amp alternator for my Toyota Tacoma DoubleCab and its is of top notch quality. You can also find him on www.termpro.com
Old May 12, 2004 | 11:01 AM
NisAznMonk's Avatar
Oh, and Dominick's forum name is trafficjamz.
Old May 13, 2004 | 03:02 AM
DenZinz's Avatar
Default Re: Warranty
Mike R.
rolex87
Caps still put strain on your alternator.
Old May 28, 2004 | 08:32 AM
Phaze23LBC's Avatar
I just got a 200 amp alternater installed in my Xb for my SQ system. Got it installed at Speaker Works in the city of Orange, California. Look them up on the internet and use "USD" for key word. These guys are unbelievable!
Old May 28, 2004 | 06:30 PM
Minsk99's Avatar
What are things to watch out for or consider when putting on a higher then stock amp alternator. Is it possible to put too much amps or is the alternator regulating 13.8 volts (that seems to be what our xB's are puttin out) and the unused amps are kinda like having torque at an specific rpm that is not being used to generate hp (as in you got it if you need it). Also, can turning a higher amp generator in an alternator be a strain on the engine? One last question. I know that it varies from each manufacturer, but approximately what is the cost of having an aftermarket alternator made/ordered for the xB (say around 200 amps)?
Old May 29, 2004 | 04:45 AM
usdmbB's Avatar
[quote="Phaze23LBC"]I just got a 200 amp alternater installed in my Xb for my SQ system. Got it installed at Speaker Works in the city of Orange, California. Look them up on the internet and use "USD" for key word. These guys are unbelievable![/q
uote]
Two thumbs up for Speaker Works, These guys have been at the top of the game for years and that means at least 15years.
Old Jun 3, 2004 | 03:19 AM
the_saint's Avatar
Originally Posted by Minsk99
....Is it possible to put too much amps or is the alternator regulating 13.8 volts (that seems to be what our xB's are puttin out) and the unused amps are kinda like having torque at an specific rpm that is not being used to generate hp (as in you got it if you need it). Also, can turning a higher amp generator in an alternator be a strain on the engine?....
iirc you can never have too much (many :? ) amps output. the more the better, it just makes it easier for you to run more stuff (greater electrical load just make sure you don't strain the rest of the wiring) voltage is what does the damage, too much and you fry stuff, not enough and it drains.
"unused amps" don't do anything, but when you add to the amp load it does add to the physical load on the engine. the alt creates more resistance with the greater amp load and therefore the engine has to work harder to spin the alt
this info is coming from the catacombs of my memory, so if i AM wrong, feel free to correct, but i "think" this info is pretty accurate.
yupinmytC
22
Jul 27, 2024 07:08 PM
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
SJMiller
Sep 12, 2015 06:33 PM
bmxScion
Jul 23, 2015 12:07 AM
SFXB
Jul 9, 2015 11:00 PM
