sdparks
09-26-2005, 03:00 PM
I’d never want to submit anyone to the torture of the center rear seat in the tC, so I don’t need a center rear seatbelt. I figured I’d clean up the looks of the rear seat area by hiding the center belt. This is a reversible modification, but can’t be undone quickly.
Tools needed:
- pliers
- socket set
- razor blade (optional)
Parts needed:
- small piece of black cloth
- zip ties (optional)
Before:
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1943.jpg
Tilt the right side seat back forward and pull back the spring loaded gap cover.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1945.jpg
You’ll find that the back of the seat is mostly zippered on, with a few metal rings along the bottom.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1947.jpg
Spread the rings apart with pliers and remove them. If you have some zip ties to use during reassembly, you can just throw the rings away.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1950.jpg
Unzip the cover and this is what you’ll see. Pop off the plastic cover.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1951.jpg
Pull up on the front of the seat bottom cushion on each side to disengage the clips, and then slide the cushion forward a few inches. You’ll see the mounting point for the end of the center seatbelt. Remove the bolt and the end of the seatbelt. Then screw the bolt back in so it will be there if you ever need it.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1955.jpg
Pop off the small cover that the seatbelt comes through on the top of the seat back and slide the belt out of the slit. This cover can be a real pain, but you’ll get it.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1956.jpg
Run the belt back through the opening in the top of the seat back, lay the belt down back over the retraction mechanism, and tuck the end in as shown.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1958.jpg
Replace the large plastic cover, making sure you get the hooks engaged. Then zip the fabric cover back on and replace the metal rings (or use zip ties).
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1962.jpg
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1963.jpg
Route the latch end of the center seat belt as shown.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1959.jpg
Replace the seat bottom cushion, making sure to engage the hooks properly. Also be sure that the latches for the outer two seatbelts show through their cutouts. Push the cushion all the way back and then pound down on the front edge to seat the clips.
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1960.jpg
Replace the small cover in the opening at the top of the seat back. Use some black felt or other fabric on the underside to block the opening. The best solution would be to wrap the entire cover in the same fabric as the seat, but I’m not that ambitious.
Now, doesn’t that look better?
http://www.scionlife.com/tech/images/seat_belt_delete_tc/IMG_1965.jpg
To clean things up even further, use a razor blade or sharp knife to carefully cut the stitching holding the tags onto all of the seatbelts. Don’t cut the belt itself! Remove the tags and the cut thread loops. You’ll be surprised how much this helps to clean up the interior.
Tools needed:
- pliers
- socket set
Parts needed:
Before:
