passenger side higher than the other!
i installed tein s on my tc and i notice the back passenger side was an inch higher than the driver side...it seems that the whole right side is higher....whats up with that?
see i noticed the same thhing on my box....then i found the porblem...might be the same for you...
instead of setting the spare tire dead center in the car, they put it off to the left..meaning that there is more weight to the left of the car....meaning it will sit lower....i dunno, just my thoughts
RedneckwithanxB, If the position of the spare tire causes your whole car to lean, I can't imagine what happens when you get in the driver's seat.
hmlbtz, did you personally install them. If so, did you make sure they sat properly in the top rubber bushings? Also, some springs will be a little off at first, but will later settle into a uniform stance.
xBSciontist
Jun 18, 2019 03:06 PM
mischadoll
Mar 9, 2015 05:48 AM
