Camber Kit or not?
Old Sep 28, 2005 | 03:13 AM
CaptainSaveAHoe's Avatar
Default Camber Kit or not?
Im planning on getting my tc lowered as soon as i can get some information on a couple of questions i have. If i lower my tc more more than an inch n a half, would it be a good idea to get a camber kit for it. If it is necessary, where would i be able to get one for a scion tc. Also, where would i be able to buy shocks for the tc. Thanx
Old Sep 28, 2005 | 03:46 AM
BigSteve's Avatar
Its not a must but not a terrible idea so that you can dial in things a little bit better. As far as i know the only company that makes a camber kit is Hotchkis.
Old Sep 28, 2005 | 07:32 AM
chimpandrew's Avatar
You'll need a camber kit. Heres one made by EZ CAM which is a reputable company that makes OEM camber kits for some companies.
http://b2b.tunerznetwork.com/product...products_id=46
As for shocks, i think that the TRD ones are one of the best out right now.
http://www.trdsparks.com/displaypart...1&parts_id=324
$459... not bad IMO.
Old Sep 28, 2005 | 11:30 AM
ack154's Avatar
Moved to CC...
Old Sep 28, 2005 | 12:53 PM
aarontrini85's Avatar
the camber bolts look good but ummm why does that tunerznetwork.com look so mutch like tc tunerz???? i would stay away from that site lol
Old Sep 28, 2005 | 01:29 PM
BrEaK_AwaY's Avatar
you wont been a camber kit for that. but if you want to get one, hotchkis makes a very good set for the rear.. i purchased them, then sold them... lol
Old Sep 28, 2005 | 06:27 PM
hahaitzskippy's Avatar
^^ here here
camber kit is there not to correct camber angle but to make it ADJUSTABLE for racing purposes.
ya you can buy it and set ur camber angle to 0 to maximize the life of yoru tires but you wont get much more life than if no camber kit.
with a lowered TC, the camber angle isnt tat bad. less than 1* will not do a lot of damage to yoru tires.
Old Jan 18, 2007 | 02:19 AM
Xxgosumastaxx's Avatar
Default Tire life very poor
I have my steel belts showing form camber issue, very very bad. and 1* is very very bad, camber issue should be no more than half a degree on both sides.
If you want a good and affordable fix. Your local alignment should should have camber bolts which replaces one of the bolts that hold your strut in place, with this it can adjust camber. The product costs about $20.00, however you need to align the vehicle to adjust to correct negative camber. For that the cost would be whatever the rate is at the shop.
Old Jan 18, 2007 | 02:44 AM
Tcguy85's Avatar
i installed hotchkis springs two weeks ago and today i had a local shop do my alignment and it cost $90 and they got my camber within spec. it was -2.0 degrees in the back, they got it to -0.6 degrees. they said the spec is anywhere from -0.9 to +0.5 for the back on the tC. the front was very close i don't remember the #'s. so they got it within spec w/o any extra parts.
Old Jan 18, 2007 | 03:57 AM
Neothin's Avatar
god! what's with bumping year and a half and older threads lately?
Old Jun 30, 2008 | 09:00 PM
TwztedtC's Avatar
Got my car aligned today and they couldnt do anything to my rear so I have to get a rear camber kit any ideas?
I love bumping old threads shows that I used the search button lol
Old Jul 1, 2008 | 01:34 AM
geo46_2's Avatar
ok so far ive been reading about camber kits but from what i understand they align your tires from
to
My other question was there was a reason why they camber in the first place? And if i do get a camber will i lose any handling i have now? im droped 1.5 front and rear w/ Tein SSp Will i need a camber kit for the rear?
Old Jul 1, 2008 | 03:41 AM
TwztedtC's Avatar
i just picked up the spc rear camber kit from wesellcarparts.com
Old Jul 1, 2008 | 06:08 PM
ack154's Avatar
There is adjustability to the rear without a camber kit. If the shop wasn't able to do ANYTHING with it, they're a crappy shop. Go somewhere else. They may not be able to get it 100% within spec, but it can be adjusted.
Camber kits can be for different reasons. Some people should get them if they're slammed or need the extra adjustability to get it within spec depending on suspension geometry.
Some people want it to go with more negative camber for racing or other reasons.
Unless you're lowering about 2" or more, you really shouldn't need one to get an alignment. And even a tiny bit out of spec on the rear won't be a problem anyway.
Old Jul 1, 2008 | 08:17 PM
TwztedtC's Avatar
well my car is on tein stechs and its 2" andthe neg camber is awful cause it is killing the tires
Old Jul 1, 2008 | 08:36 PM
ack154's Avatar
It's likely not the camber that's killing them. More likely is the toe. That's what destroyed my tires when I first dropped my car. Negative camber isn't really a bad thing unless it's extreme. But toe in (the front of your tires point inward) will shred a set of tires pretty fast.
jcraff3
Feb 20, 2015 11:41 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
Mr_Magu
Jan 17, 2004 05:21 AM
randode
10
Dec 11, 2003 06:05 PM
