View Full Version : Which BBK- Wilwood or Rotora?
suby2scion
10-02-2005, 10:55 PM
I can get a new Wilwood BBK for $915 shipped on eBay.
Or, I have a hook-up to get a Rotora BBK for $985 plus tax and shipping (total would be under $1,100)
I like the fact that the wilwood calipers are black...I'm not sure if Rotora offers black calipers. But I remember hearing back when I had a WRX that the Wilwood BBK's did not have dust shields or something like that so they required frequest cleaning and maintenance.
I don't want to discuss whether I need a BBK or not...I just want opinions on which one to get, especially from those of you that have these.
Thanks!
Revilo
10-02-2005, 10:57 PM
price and name... Wilwood... get it...
bubblemyster
10-02-2005, 11:34 PM
wilwood. name brand.
raamaudio
10-03-2005, 08:04 AM
Rotora seems to be a good brand as well, never heard otherwise and a few I know that own them are happy:)
I would not get drilled rotors for the street, whatever brand you get, ask for slotted rotors or solid;)
I went with Wilwood, very low weight, excellent quality, I pick what brands I want on the car then seek sponsorships, in this case Wilwood is what I wanted, asked for and got, all for good reason:)
Rick
jlaznlover
10-03-2005, 05:17 PM
i would get the black wilwood kit. some of my friends that have the wilwood kit are very happy with them(not for the tc though). i dont know anyone that has a rotora kit, so i have no real opinion on them.
i emailed them a few months ago. rotora offers a painting service for the calipers. it would cost $100+ (forgot the actual amount, but i am positive it was over $100) for custom color(other than the standard blue or red)
rhythmnsmoke
10-03-2005, 06:42 PM
Why not drilled for the street?
xlr8tC
10-03-2005, 07:07 PM
drilled can crack sometimes. the only reason you would drill is for heat dissipation and on the street you won't see nearly that much heat. even if you street race. you see cross-drills on high end sports cars b/c they can achieve those higher mph's where the brakes will get full on hot real quick. i'm not saying it's impossible to get there on street, but, it's very unlikely. i think we need to figure out how to make some liquid cooled brakes. that would be the ticket. i thought i heard about some once, but it turned out to be a rumor.
raamaudio
10-03-2005, 07:26 PM
There are alot of different opinions on drilled, slotted, drilled and slotted, etc, etc and I have done a fair amount of looking into this. Plus, I worked out our best solution with a Wilwood engineer so fairly comfortable in what we selected, sloted rotors.
Our rotors are sloted only because we will drive it on the street so want them to last, not drilled because the heat on the track can actually make them crack sooner as well. (Notice I said sooner, not may make them crack;) Generally, advisable to stay with plain or slotted only rotors for these reasons.
Super high end sports cars are hardly ever driven alot of miles, owners expect high maintenance and high parts costs, super big brakes can be very heavy, drilling can lessen that a bit, etc... Best not to compare totally different vehicles, use, budgets, etc, etc.
Rick
Race cars go through brake rotors like some of us go through underwear, or at least should, quite often, lol! Drilled rotors can have a significant benifit in performance and are expected to have a short life.
Drilled rotors for most all street driven vehicles is eye candy at best.
lo_bux_racer
10-03-2005, 08:36 PM
Drilled crack sooner under heavy use. They use them on racecars not for heat, but for weight. They expect to ruin them during the course of a weekend, so they are a high maintnance item. You do not see them on weekend warriors.
It is practically impossible to get brakes to racing temperatures on the street, just as it is practically impossible to get racing tires up to temperature on the street. You just can't go fast enough, long enough. Once you've been to the track, you'll know what I'm saying.
There are liquid cooled brakes. NASCAR short track racers use pumps and heat exchangers on the brakes to circulate the fluid to help get the heat out of the calipers. They are very much liquid cooled, just not with a separate system and a different fluid.
rhythmnsmoke
10-03-2005, 09:20 PM
I know what drilled is for. Here, let me restate it this way. Drilled is designed to be thrashed on. That's when you are doing some serious manuvers. So, for the most part, they are designed for track use. So, if you use them on a street car, they are not seeing the same amount of wear & tear that you would on a track car. So, if there is no wear & tear, then why would they crack? They are designed to dissipate the heat better, but if there is no heat to dissipate, then wouldn't that equal longer life span? I assume you mean they will crack from high use. But they are designed for high use situations, but on the street those situations are rarely seen. So, again, what's wrong with drilled on the street?
lo_bux_racer
10-03-2005, 09:30 PM
No, they are NOT designed to dissipate heat better, and they won't ever do that. They were originally designed to allow trapped gas from organic pads to escape because the gas would push the pad off a solid faced rotor. No other reason.
Drilled crack sooner, period. This has been reported MANY times by street and track users. The only drilled rotors in any current series I know about are in ALM because they are looking for any advantage, however tiny, to be competitive.
I can give you a quote from a good friend of mine who placed fourth in the 2003 One Lap in a Supra "drilled rotors suck!"
His rotors failed half-way through the race and cost him considerable down time to replace with OEM rotors that had no issues completing the race (and they hadn't even got to Road Altanta yet!)
rhythmnsmoke
10-03-2005, 09:39 PM
To a degree, they do dissipate heat better. But I knew about the trap gas functionality as well.
The_Instigator
10-03-2005, 09:40 PM
Once again lo-bux is right. There is however another benefit to drilled rotors which is increased bite characteristics over a blank or slotted rotor and are still sometimes used on the rear brakes of some racing cars (where the heat is not as much of an issue). It is true that drilled rotors are prone to cracking, but on a street only car it is unlikely to happen (unless they are of low quality). Drilled rotors have been phased out on race cars not only for their short life, but current brake pads dont have the same ougassing characteristics they used to have. New technology has reduced that to the point of being a non-issue after a proper bed-in procedure. When looking at slottd rotors, be sure to watch for slots that go all the way to the edge of the rotor. This can creat a weak spot and lead to rotor cracking as well. :no:
kungpaosamuraiii
10-03-2005, 10:45 PM
On the street, the "advantage" of drilled rotors is a lighter weight and therefor less unsprung weight. But I figure it's akin to a spoiler helping out with downforce on a street car.
lo_bux_racer
10-03-2005, 11:05 PM
Well said!
suby2scion
10-03-2005, 11:50 PM
Anyway we can get back to the original reason for this post guys????
Magnus213
10-03-2005, 11:53 PM
I thought the man just wanted advice on which kit to buy!
I will admit, though, that the discussion has been very informative and well-mannered. I'm learning.
Carry on.
apexjr
10-04-2005, 12:35 AM
I go for Willwood or Stoptech. I don't know much about Rotora, but I have seen a kit on the TC and it did not look bigger then stock, not by much. The Stoptech is 2 inches larger then stock! Not to mention that, the Stoptech ones are all about balance. You get the bigger rotor so you can stop more often harder, but they also balance the break system a bit better so the rears work a slight bit more and bring your stopping distance down at the same time.
I trust Stoptech, but I also trust Wilwood. The customer services from Stoptech is wonderful as well. I'd compare weight, warranty, specs, etc between Stoptech and Wilwood and then decide. To me, brakes are NOT an item I seek economy in.
The_Instigator
10-04-2005, 01:08 AM
TRD Big Brake Kits are rebadged stoptechs....not sure if that means anything to you or not., but TRD stuff is always top quality. I doubt you can get them for the price you mentioned earier though.
lo_bux_racer
10-04-2005, 01:34 AM
Sure. Buy the color you like best. It's for a street application, and there's no way you'll be stressing any of these brakes to their limits, so it really is a cosmetic choice. Pick what looks good and fits your pocketbook. JMHO.
suby2scion
10-04-2005, 03:15 AM
Yes, I agree with that...I'm sure there's little to no difference in stopping power with the 2 systems.
However, I am concerned about things like noise, maintenance, cleaning, etc...and wondered what others have noticed with these.
JDMxB
10-04-2005, 03:22 AM
Willwood, easily.
People get Rotoras to put on their show cars to look nice sitting at shows.
raamaudio
10-04-2005, 07:23 AM
If not for being a part time show car(not a show queen by any means) and the fact we plan on track days with race tires and around 300WHP, we would stay with the stock brakes as they are quite good with the right tires(suspension helps as well)
With just the stock fronts and slighly upgraded rears(to go with the new fronts when we have time to install them) a 60 mile run through some of the funnest twistes I have ever come across, pretty dang quick pace, 30 miles up, then 30 miles down the other side, not one brake issue, stock was just fine.
With upgraded pads would of been even better.
Nobody kid themselves here, upgrading to a BBK for the street is cosmetic only.
Rick
-Keith-
10-04-2005, 03:06 PM
Just so you know willwoods will have to be tore apart and cleaned every so often. They do not have dust caps on the pistons
raamaudio
10-04-2005, 04:57 PM
Thanks, Not really a problem for us since we do alot of maintenance and continually look for ways to improve the car. Though daily driver capable we do not drive our project cars on the street all that much, just not enough fun and to many bad drivers around so just to and from events and meets, which we will be doing most weekends during the season up here in the Northwest as well as a few in CA, etc.
Plus, we will be changing pads for a number of events each year, another good time to clean things up:)
I imagine just getting the dust off around the pistons is all that is required, if so that should be an easy job.
Rick
-Keith-
10-04-2005, 06:20 PM
No I have a friend that works on a porsche scca car... and In order to clean em you have to disasemble them
raamaudio
10-04-2005, 06:33 PM
Ok, thanks for the headsup!
Rick
Acsilva84
10-04-2005, 07:19 PM
i would go with the wilwood breaks
