View Full Version : xA - Amp install location ? (Updated w/ pics!)
koan
10-03-2005, 05:27 PM
I just picked up an Alpine MRP-M350 ( http://www.crutchfield.com/S-sUbhoBIipvz/cgi-bin/prodview.asp?i=500MRPM350&g=120&search=m350 )
Its pretty small ( 9-3/16"W x 2-7/16"H x 9-9/16"D ) so I would hope to hide it away as much as possible. It looks like there is plenty of room under the front passenger seat but I would like a location that is a little less exposed.
I'm trying to figure out how i can squeeze it into the rear compartment without sacrificing my spare. Any ideas?
If the under seat location is best, does anyone have any hints on how to protect it a bit better?
DoggyStyle
10-03-2005, 06:11 PM
I have a single 10" in a small sealed box in my xA. Yeah under the front seats is def an option. I mounted mine to the reaer of the sub box. I have my box facing the hatch so the amp is between the rear seat and the back of the box. Not visible and I ensured I left a little slack so I can still access the spare tire.
koan
10-03-2005, 07:43 PM
I guess I should have also mentioned one of my goals is to be able to fold the seat down and still have the full cargo area (what little there is!). I have a seperate sub box I can simply remove it as desired, but I didnt want to have exposed wiring, etc from a removed amp.
DoggyStyle
10-04-2005, 11:40 AM
OK I guess your options then are somewhat limited. Under the front seat sound like the best plan of attack. I never fold the seats, well almost never.
Does the xA have a small storage area next to the spare tire area? Funny I own a xA and never have looked. I heard the xB does and people have used that to some degree. Maybe we'll get lucky and find something new.
koan
10-04-2005, 04:14 PM
It does have the area but its a bit smaller from the looks of it.
I was checking it out last night and I think it may just fit.
1) Put the tools on the other side or the tire.
2) Remove the 2 bolts and plastic well
3) Cut just a bit of the plastic that covers the wheel well.
#3 is iffy - I have to look a bit closer tonight. I think the plastic covering the wheel well protrudes an inch extra from the metal of the well. If i cut a small rectangle out of the bottom for the amp, it should give me just the bit of extra clearance i need.
*fingers crosssed*
DoggyStyle
10-04-2005, 06:13 PM
Sound like a good plan to me. Let me know how you make out. I guess I should look under the rear carpet for myself sometime. :P
koan
10-09-2005, 07:27 PM
Success!
Here are some pics:
Wheel well with plastic removed and right panel cut:
http://rosewood-subdivision.servepics.com/pix/IMG_0670.JPG
Close up of work/mounting area:
http://rosewood-subdivision.servepics.com/pix/IMG_0671.JPG
You can see in the above picture I didnt cut all the way back to the end of the side panel plastic. I left a "leg" for support of the above plastic and because I didnt absolutely need the extra inch at the top. I did however cut a channel for a few wires to get through. Here is a close up of the area:
http://rosewood-subdivision.servepics.com/pix/IMG_0672.JPG
Next I installed a wooden mount plate made from cheapy plywood. I cut the wood a little long on the side that goes toward the passenger side panel so I wouldn't put to much force on the wires that will be housed there. I then cut 5 holes: 4 for bolts coming up form the bottom to mount the amp and one to mount the plate to the flooring using the stock plastic hole that was already there:
http://rosewood-subdivision.servepics.com/pix/IMG_0673.JPG
And the final product:
http://rosewood-subdivision.servepics.com/pix/IMG_0674.JPG
Certainly not the cleanest or most professional install, but it gets the job done nicely and is 100% stealth while loosing none of the functionality of the trunk space. Also, if I ever need to go back to stock, I can easily reinstall the plastic bucket in its orginal location and none of the cuts I made would be visible
zyzyx6969
10-09-2005, 08:44 PM
kool :)
TheScionChef
10-10-2005, 11:34 PM
here is what i did with the amp i just had it slanted on my box with the two subs many people at shows says it looks great and asked me were i had it done but i did it my self took about 3 hours to build the box and like 16 hours for paint to be done properly along with all the silcon and sealing of the boxhttp://community.webshots.com/photo/406026336/406026336IkuMDg
koan
10-10-2005, 11:40 PM
Looks nice, I contemplated doing something similar but as my previous posts pointed out, I wanted something I could detach w/out exposed wiring (I suppose someone must make some sort of quick release connection...)
Can you still fit the stock cargo area cover/screen over the top without it bulging? That was one of the other considerations I took into account when going with the setup I did. I went with a truck box lying on its back ( http://www.crutchfield.com/S-46SVOpmwTuJ/cgi-bin/ProdView.asp?g=178650&I=044T1012SS ) and an Infinity Kappa Perfect 12.1D - You can't really tell its not stock from the outside :)
Also, if i have something dirty that I dont want to carry on my rear seats, I can also detach the sub box and re-attach it in the back seat sitting upright. Cargo + Bass ;)
I guess I should post pics of the box/sub too :doh:
