OTG's installed! Thanks Precision Muffler!
Old Oct 3, 2005 | 08:05 PM
Prototype_xB's Avatar
Default OTG's installed! Thanks Precision Muffler!
Wow, Precision Muffler worked quick!! I ordered One Ton Garage spacer shims several days ago and they arrived today!! All the way to NC from CA already!!
BEFORE:
After:
Before:
After:
Not a mod that makes a SUBSTANTIAL difference, but it gets rid of the negative offset eye sore the rear axle had.
www.PrecisionMuffler.com
Old Oct 3, 2005 | 08:30 PM
BrianGillen's Avatar
Nice, I've been waiting to see how this would look.
What size spacing are those? I've been meaning to pick up a set because I hate the hidden wheels look. Ahh, do you know if the fronts are in less than the rears, or could I just buy a set of 4 spacers and not have to worry about them being different ? Should I make them different? I hope you undertsand what I'm trying to say. Glad to see what this mod looks like finally. ANy healp would be appreciated.
-Brian!
Old Oct 3, 2005 | 08:33 PM
Max's Avatar
Max
Looks good.
Moved to T&B
Old Oct 3, 2005 | 08:41 PM
450xB's Avatar
awesome!!!!!!!!!!!!!!!!!
Old Oct 3, 2005 | 08:44 PM
Max's Avatar
Max
Pretty funny that you edit your images to hide the license plate, yet show the box for the shims with what appears to be your address on the front, easy to read.
Old Oct 3, 2005 | 09:02 PM
like the irony huh? The cencoring the license plate is just a habit i picked up from 7thgencivic.com
Old Oct 3, 2005 | 09:04 PM
-Brian!
The rear is offset 10mm from the front axles. These spacers are 10mm. They move the rear out to where the front wheels are.
Old Oct 3, 2005 | 09:07 PM
David_Seale's Avatar
so did you use spacers OR shims? or both?
Old Oct 3, 2005 | 09:11 PM
Ok cool, thank you!
So you said you had some rubbing with the 10 mm spacers, right? I read another post. Were the spacers available in say, 5-7 mm? I also noticed it might have been your tire width. When you get that worked out fill me in as to which it was. Maybe this weeknd I will just go pick some 10 mm spacers up, I plan on running stock wheels with some beauty rings so I might ot have that prob.
Does 10 mm on front and 20 mm rear spacer be a bad idea? Would to much wheel be hanging out of the fender? I'll give it a shot. Based on what someone replies. Maybe i'll buy all sizes and see what goes on. I'll definatley post pictures of all setups.
Is there an engineering problem I might want to avoid by have 10 mm front and 20 mm rear spacers?
If anyone can help out, that would be neat.
Thanks,
-Brian!
Old Oct 3, 2005 | 10:07 PM
Just shims right now. These bolt onto the back of the drum. I may buy some 5mm spacers as well so the rear will stick out a lil further than the front.
Old Oct 3, 2005 | 10:13 PM
Ok cool, thank you!
Thanks,
-Brian!
I haven't ever had any rub. With or without the shims.
You'll have problems with a 20mm rim spacer. The lug bolts are only 25mm or so long.
I saw a spacer kit in the Sponsored Sales section for $200 shipped (set of 4) that are 25mm, and solve the problem with the lug bolts. Let me find it......
https://www.scionlife.com/forums/vie...=81930&start=0
Old Oct 19, 2005 | 07:33 PM
Guest
Guest
Posts: n/a
So glad we were able to get those to you as fast as we did, the USPS works great for us over here in cali. Always great to hear from a satisfied customer. :D
Old Oct 19, 2005 | 07:45 PM
HoTBoX009's Avatar
nice pics!
NonStopTuning
Jun 29, 2015 07:42 PM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
scionspecialistvegas
Nov 9, 2003 08:18 PM
