Anti fouler trick for the CEL Questions
Old Oct 8, 2005 | 04:53 PM
toyota_scion_tc's Avatar
Default Anti fouler trick for the CEL Questions
Out of the people that have done this and already have at least 60 miles or more what did you actually do? I read on the forum search and tried doing that way and it doesn't work. I have tried this mod three diffrent ways but my CEL still comes on. What mods do you have? Please anyone with header and s-pipe help!
Old Oct 8, 2005 | 05:15 PM
miamibusta69's Avatar
i have the ati-fouler aswell and my cel keeps coming on ..... I need to get the code checked but i think my o2 sensor is broken.. If it is broken will the camry o2 sensor work?
Old Oct 8, 2005 | 05:43 PM
metalranger33's Avatar
my o2 was broken also
Old Oct 8, 2005 | 06:18 PM
How much was a new one?
Old Oct 8, 2005 | 08:01 PM
BrEaK_AwaY's Avatar
you need 2 antifoulers. the firest one gets into the spipe, the sencond one needs to be bored out with a 1/2" drill bit, then attach that antifouelr to the other one, and the 02 sensors goes into the bored out fouler.
hope i helped
Old Oct 8, 2005 | 09:25 PM
hope i helped
Did that, and it didnt work! What mods do you have? I have the CAI, Alpha werks header, s-pipe. The anti fouler trick didn't work.
Old Oct 8, 2005 | 10:41 PM
BrEaK_AwaY's Avatar
did u disconnect the negative termial from ur batter for a few minutes to reset ur ecu?
Old Oct 9, 2005 | 04:51 AM
I bought my antifouler only 1 but it was a 2 peice from clubsciontc.com DO i have to buy another one? i need to fix this problem im wasting gas like a mo ____a
Old Oct 9, 2005 | 11:39 AM
I pulled the ecu fuses
Old Oct 9, 2005 | 02:29 PM
BrEaK_AwaY's Avatar
i would assume the fuse would do the same thing. cause its still removing power. i dunno man
Old Oct 9, 2005 | 03:18 PM
TurtleCrusher06's Avatar
hey i have alphawerks header, scion tc performance stage II intake, and what I did is did the whole two anti foulers bored it out to a 1/2 inch then had a buddy take his scanner ( he works at a shop) and wipe the cel message, pretty much restarting it. So my suggestion is that you take your car to a nearby shop and see if they can't scan your ecu for you and get your cel off, and if the anti foulers aren't doing there job your cel will just simply come back on in the next couple of day. Good Luck hope i helped.
Old Oct 9, 2005 | 03:22 PM
oops didn't mean to put that all in a quote i am new to this
Old Oct 9, 2005 | 04:45 PM
I have a adapter for my laptop to scan my car. I have been reseting the cel myself. I am driving around now waiting untill it pops on again. Anyone that has this mod and has a scanner their self that will read live data read the h02s sensor voltage with it running and tell me what yours displays. Thanks for the help.
Old Oct 9, 2005 | 07:37 PM
hey toyota_scion_tc this is a little off topic but how does your set up sound cuz i got an intake and same header as you and I am looking for an exhuast that wont sound crappy with my current setup, so if you could let me know how yours sounds that would be great! thanks, and i would let you know my h02's but im at work today.
Old Oct 9, 2005 | 07:39 PM
My injen ses in awaiting customs right now. I should have it in a 7-14 days hopefully. I will try to post a sound clip when I get it.
Old Oct 9, 2005 | 07:46 PM
awesome, axle back or cat back?
Old Oct 9, 2005 | 07:48 PM
eveyone says the injen ses exhaust is an axleback but injen told me its catback. I am not sure. I belive it connects to the oem resonator on the car.
Old Oct 9, 2005 | 11:48 PM
tcsciontist's Avatar
that resets ECU??
then why not just do that when you add new performance parts??
Old Oct 9, 2005 | 11:57 PM
BrEaK_AwaY's Avatar
yes, disconnecting the battery resets the ECU, and you should do this everytime you isntall a new part that has anything electrionc to do with it (such as a sensor).
the injen is an axel back exhaust. the resonator is just before the rear axel.
Old Oct 11, 2005 | 11:54 PM
Ok I did the anti fouler trick and it doesn't work I keep getting p0136 cel code. The people that this has worked on did you have a header and a s-pipe. This is the only conclusion of why the cel keeps coming on. If anyone has other experiance on the solution please let me know. I have the alphawerks header and zpi s-pipe.
