Switched Iridium Plugs - Big Difference - Must for Turbo
Well, last night while my daughter slept, I switched out the stock plugs with the Denso IK22 Iridium....a colder plug...
I figured rather than plant it in her head of any difference, I didn't say anything about it so I could see if she did notice anything.
She left for work this morning and called about an hour ago out of the blue.
She asked if I did something to her car. I said no, why, what's wrong (I thought something was really wrong)?
She said nothing was wrong, but it's the weirdest thing.
When I drove to work this morning, the car for some reason had quicker response when I push on the gas and felt like it ran stronger , even into boost. It idles better and I didn't even hear one backfire. It's the strangest thing. Is there anything that could have just broke in or something?
So, I started laughing and told her I did change the spark plugs. I just wanted to see if there was going to be any noticable difference and not telling you would be the only way to get that info without tainting it.
The stock iridiums I took out looked really good. It appears from them the AFR is just fine....I'll grab a few pics of one and post. They have about 2000 miles with the turbo on them.
Originally Posted by PoizentC
Thanks for the info. I'm going to pick some up today. When switching to a colder plug, do you just go 1 step down?
Glad you have had such good results, I tried one step colder Iridiums in my 13PSI Matrix and it just did not work. Then I tried Platinums, no better, was advised to go with copper, one step colder, had to order the right plugs, then it made a very significant improvement. Though the A/F was correct on the other plugs it would misfire fairly often at high RPMs.
Then again, that was at 13PSI;)
Rick
Rick
That's consistent with what I've seen with Supras. They like iridium plugs a lot. One step colder should be all you need for street, but for a track day, I'd put in two steps colder.
I suspect you were getting timing retard with the hotter plugs, and now you are not. It would have been interesting to log EGT before and after.
Rick
Rick
Denso's are some good plugs, imo.
Start here. You would be wise to read everything you can find on the NGK site, you'll be able to detect serious BS from a long distance when people are telling you about what changing a plug did.
Follow the basics with this and focus on the bits under the Plug Construction Features to Consider heading. Lots of helpful info there.
